cab mount is broke
cab mount is broke
Postby 95ram » Wed Jul 08, 2009 3:35 pm
I searched and didn't really come up with anything. My rear D side cab mount is broke and the cab has shifted to the D side. I have a donor pickup that I could snag the mounts off. My quesiton is will this work. Is it as easy as cutting the rivets out and bolting the new cab mounts in?
95ram
Postby PToombs » Wed Jul 08, 2009 5:38 pm
If you mean the frame part of the mount, yup, it's that easy. I had to change 2 of mine.
Postby 95ram » Wed Jul 08, 2009 7:08 pm
yeah it's the part that's riveted to the fram and then the bolt goes up into the cab.
95ram
Postby Richie O » Wed Jul 08, 2009 7:57 pm
Mine were real thin on the 93 where the rubber sat on the mount so I welded big washers on the top. The rest of the mounts were plenty strong.
Postby 95ram » Wed Jul 08, 2009 11:13 pm
the rear D side is completely broke and the rear P side is cracked. I plan on putting a new/differant one on the D side and welding a washer to it and fixing the P side and welding a washer to it also.
95ram
Postby PToombs » Thu Jul 09, 2009 6:13 pm
My front ones were rotted thru, so I swapped them from the '86 donor truck. The rears were different, so I cut a square out of the bad mount, and made a replacement piece to weld in. Went right to the edges where it was thicker. Worked pretty good. 8)
