The time has come. New trans time.
Re: The time has come. New trans time.
Postby cmann250 » Mon Mar 03, 2014 6:35 pm
ellis93 wrote:Sure.....listen to a salesman. :roll: nevermind about all the "experienced" folks telling you the same.
EVERYTIME I ask BC says "Call them, call them, call them, call them." So I did.
They confirmed my hunch. :lol:
That's good to know Pete. At least I'm not the only one.
Postby BC847 » Mon Mar 03, 2014 8:02 pm
My head is off apparently tonight, not sure which band is giving you a fit, but . . .
Which band is giving you a fit?
Postby cmann250 » Mon Mar 03, 2014 8:24 pm
The rear band was resisting me before I figured it out. I had to put the strut in without the drum installed.
Postby txs » Wed Mar 05, 2014 9:15 am
caleb, the 904 and 727 always got the band put in before the drum, while the trannies went down the assembly line. I have had some struts that were difficult to get in with the drum installed. The main advantage of a 47 over the 727-518-46rh is the double wrap L&R band, no anchor and apply linkage, the lever applies directly on a protrusion of the band.
txs
Postby cmann250 » Wed Mar 05, 2014 9:24 am
Thanks for setting me straight Tom.
I have a shift kit here waiting. I'll likely install it this evening.
Postby PToombs » Wed Mar 05, 2014 6:22 pm
10 pages and you're not done with it yet!?!?! :roll:
Postby cmann250 » Wed Mar 05, 2014 6:32 pm
Zing! There goes the detent ball. :roll:
I need to take the VB out of my spare to see how they go together anyway. There was all kinds of black slime in it.
For whatever reason, I didn't have a #9 check ball. I'm 99.9% sure that I didn't drop it because I disassembled the VB the right way. Fortunately I don't need it because the shift kit I have replaces one of the other balls. #9 softens the engagement of Low or Reverse. I know my 727 really bangs into reverse.
Any one know anything about this?
PToombs wrote:10 pages and you're not done with it yet!?!?! :roll:
Yea and going on 10 months :lol: I've actually owned the for less than half of this thread.
Postby ellis93 » Wed Mar 05, 2014 8:00 pm
cmann250 wrote:Zing! There goes the detent ball. :roll:
My opinion......if they say put it back,put it back.
Postby cmann250 » Thu Mar 06, 2014 4:43 am
Yea I'm wanting something there because I think there should be something there. I just wonder why there wasn't one there.
Postby DodgeFreak » Thu Mar 06, 2014 6:06 am
Its optional. I believe if your separator plate has 2 holes you can use a check ball if it has 1 you don't need it. Does your new separator plate from transgo have 2 holes or one?? I don't think you can use it if it only has one hole as that is the only way for oil to go.
Postby DodgeFreak » Thu Mar 06, 2014 6:12 am
Postby ellis93 » Thu Mar 06, 2014 8:25 am
DodgeFreak wrote:Its optional. I believe if your separator plate has 2 holes you can use a check ball if it has 1 you don't need it. Does your new separator plate from transgo have 2 holes or one?? I don't think you can use it if it only has one hole as that is the only way for oil to go.
You are correct.
I just do as the Kit instructions say solely because someone designed it to function a certain way with this number of parts.......add or subtract said number of parts and your subject to screw yourself.
Postby cmann250 » Thu Mar 06, 2014 6:22 pm
When I don't really know what I'm doing, I follow the instructions. FWIW if I intended to plow and modded the VB accordingly, I'm have drilled a hole in the separator plate and put a check ball in the #9 spot.
And I have a 47RH VB for some reason. I have provisions for all the lock-up stuff, except the solenoid. Funny.
Postby cmann250 » Thu Mar 06, 2014 7:45 pm
I also don't have the converter clutch valve spring and converter clutch timing valve and spring, but that all doesn't matter because I don't have a locking converter.
I probably spent 10 minutes looking for my converter clutch valve. :roll:
Postby cmann250 » Fri Mar 07, 2014 9:45 am
Tentative install date: Monday March 17.
I'll do an R and R in the morning, get a driveshaft made at lunch, button it all up, say a prayer, and roll on.
