4 door cab and frame swap?
Postby hassy21 » Sun Jul 05, 2009 11:00 pm
I am trying to find a donor truck to make my truck a four door. I just need to know some info. on how you guys did it. Some pics of guys that already did the conversion would be pretty cool too. Thanks
hassy21
Postby RumbleFish » Mon Jul 06, 2009 5:30 am
most people swap the drivetrain into the 4 door truck. some stretch the frame instead. if you want to keep your truck a long bed, you'll need to do a frame stretch, or buy a 2wd long bed crew and do a 4x4 conversion. as for myself, if i ever find a cab and bed, plan to swap my ext cab and long bed for a 4 door cab and short bed, as the wheelbases between the two are the same. good luck.
Postby hassy21 » Mon Jul 06, 2009 2:11 pm
i want a long bed as i have the fifth wheel and dont want the trailer that close to the cab. i am just gonna do the 2 wd drive 4wd conversion.
hassy21
Postby hassy21 » Mon Jul 06, 2009 2:12 pm
what year truck do i need to find?
hassy21
Postby RumbleFish » Mon Jul 06, 2009 7:58 pm
any will do really, but it would be easiest to sart with a 80's body. they only made them till 85, so good luck.
Postby CE_TX » Mon Jul 06, 2009 8:08 pm
There is a guy on DTR that has 2 crew cabs for sale in CA. :)
1985 Dodge W350 Crew Cab with 1992 Cummins drivetrain---undergoing frame off restoration.
CE_TX
Postby hassy21 » Mon Jul 06, 2009 11:18 pm
im not sure if it the same guy but theres a guy in chowchilla about 20 min. away from me that has built 2 of them but not for sure if he is selling them.
hassy21
Postby 95ram » Tue Jul 07, 2009 4:39 pm
there is a guy in cali with two of them. he wants 1800 a piece and both are 4x4 short beds. Look at Gov. auctions around you. Most crew cabs were Gov vehicles with few a civilian being made.
95ram
Postby hassy21 » Wed Jul 08, 2009 12:15 pm
i want a 2wd long bed so i can put all of my stuff on that frame
hassy21
