4 door cab and frame swap?
both inside and out
Postby hassy21 » Sun Jul 05, 2009 11:00 pm
I am trying to find a donor truck to make my truck a four door. I just need to know some info. on how you guys did it. Some pics of guys that already did the conversion would be pretty cool too. Thanks
1990 Dodge CTD,4wd,91 frontend conversion, Skyjacker 6" lift, 6" stacks,fuel screw 3/4 turn away from runaway,366 spring,afc delete,timing bump,piston lift pump,autometer gauges,05 Dodge wheels with 35's
http://s54.photobucket.com/albums/g118/imca21/
hassy21
Postby RumbleFish » Mon Jul 06, 2009 5:30 am
most people swap the drivetrain into the 4 door truck. some stretch the frame instead. if you want to keep your truck a long bed, you'll need to do a frame stretch, or buy a 2wd long bed crew and do a 4x4 conversion. as for myself, if i ever find a cab and bed, plan to swap my ext cab and long bed for a 4 door cab and short bed, as the wheelbases between the two are the same. good luck.
Postby hassy21 » Mon Jul 06, 2009 2:11 pm
i want a long bed as i have the fifth wheel and dont want the trailer that close to the cab. i am just gonna do the 2 wd drive 4wd conversion.
hassy21
Postby hassy21 » Mon Jul 06, 2009 2:12 pm
what year truck do i need to find?
hassy21
Postby RumbleFish » Mon Jul 06, 2009 7:58 pm
any will do really, but it would be easiest to sart with a 80's body. they only made them till 85, so good luck.
Postby CE_TX » Mon Jul 06, 2009 8:08 pm
There is a guy on DTR that has 2 crew cabs for sale in CA. :)
1985 Dodge W350 Crew Cab with 1992 Cummins drivetrain---undergoing frame off restoration.
CE_TX
Postby hassy21 » Mon Jul 06, 2009 11:18 pm
im not sure if it the same guy but theres a guy in chowchilla about 20 min. away from me that has built 2 of them but not for sure if he is selling them.
hassy21
Postby 95ram » Tue Jul 07, 2009 4:39 pm
there is a guy in cali with two of them. he wants 1800 a piece and both are 4x4 short beds. Look at Gov. auctions around you. Most crew cabs were Gov vehicles with few a civilian being made.
95ram
Postby hassy21 » Wed Jul 08, 2009 12:15 pm
i want a 2wd long bed so i can put all of my stuff on that frame
hassy21
Return to Body
Users browsing this forum: No registered users and 67 guests
