More power
More power
Postby rrfarm » Sat Sep 03, 2011 6:29 pm
Hey guys new to the site and was told you all could help. I have a 92 W-350, Diesel, 5spd, 4x4. I'm doing a complete rebuild of the truck including a crew cab conversion. The truck is completely stripped down at this moment. What I need help with is I would like to have about 300 to 350 horsepower. How would be the best way to accomplish this? P-pump or VE, injectors and size, and turbo. Money is an issue so try to give me the most cost effective route if you can. Thanks in advance.
92 Dodge W350, Diesel, 5spd, 4x4
Crew Cab conversion and motor upgrade project.
rrfarm
Re: More power
Postby skilletky » Sat Sep 03, 2011 7:41 pm
pee pump would probably give you a more streetable 300 hp, but sticking with the ve is more fun. a set of guages, 4 inch exhaust, free flowing intake, turn the pump up with a 3200 gov spring, some 5x.012 or .014 injectors, a turbo (62/65/12 or 14) and some of tim's cooler tubz, and grind on yer afc pin. that should make ya pretty happy, i used to have this simaler set up and my turb ran a 14.5 in the 1/4, using the hp calculator on comp d put me at about 330ish to the ground. i was able to tow with it but i can get a little warm. you will want to upgrade yer clutch too.
skilletky
Re: More power
Postby oldestof11 » Sat Sep 03, 2011 7:52 pm
Streetable 300, VE.
Anything more, p-pump.
Re: More power
Postby AHineman » Sat Sep 03, 2011 7:58 pm
oldestof11 wrote:Streetable 300, VE.
:yuck:
Re: More power
Postby Mark Nixon » Sat Sep 03, 2011 8:34 pm
Rrfarm, glad to see that you made it here. :)
These guys will definitely not jerk you around on advice or suggestions.
Re: More power
Postby rrfarm » Sun Sep 04, 2011 11:00 am
Thanks for the response glad to be here.
rrfarm
Re: More power
Postby rrfarm » Wed Sep 07, 2011 5:01 pm
Let me ask another question. While we are talking more power how much power can you safely make without having to start beefing up the block? Thanks
rrfarm
Re: More power
Postby Mark Nixon » Wed Sep 07, 2011 5:08 pm
Way more than a VE will make.
Not much help, I know.
Re: More power
Postby rrfarm » Wed Sep 07, 2011 5:20 pm
So the 350 I would like to have would be safe without like headstuds and so forth?
rrfarm
Re: More power
Postby Richie O » Wed Sep 07, 2011 5:32 pm
No, you will need head studs for 350. Not really " need " but the head gasket will be on its way out.
Re: More power
Postby rrfarm » Wed Sep 07, 2011 5:38 pm
Anything else besides headstuds?
rrfarm
Re: More power
Postby oldestof11 » Wed Sep 07, 2011 5:53 pm
Around 800hp the wrist pins like to let loose. :lol:
Re: More power
Postby rrfarm » Wed Sep 07, 2011 6:27 pm
oldestof11 wrote:Around 800hp the wrist pins like to let loose. :lol:
That would be sweet but don't think i'll go that much.......Yet
rrfarm
Re: More power
Postby skilletky » Wed Sep 07, 2011 9:57 pm
With the setup i mentioned above, i never blew a head gasket, i had the waste gate set at 40 psi. But every truck is differnet, i didnt blow any gaskets till i started shooting water too it. But studs will give you a peace of mind.
skilletky
