top turbo shootout
top turbo shootout
Postby fatstack » Tue Feb 07, 2012 7:30 pm
Please help me choose the best turbo to put up with with stock non ic sticks, and later down the road with 6 x 16 sticks over an s400 in twins. A) s300g b) he351 c) hx40 d) 60mm hybrid hx35 e) other. Thanks
89 d250 getrag ripper, pump maxed,timed to the head,pull cable shutoff, 354 spring, straight pipe, 4:10 gears, in the shop: he351cw and 3:07 gears
90 w350 nv4500,ic motor, stock, 5" stack w a western hauler on back
fatstack
Re: top turbo shootout
Postby CumminsPower59 » Tue Feb 07, 2012 8:08 pm
If it were me, I would probably lean towards the S300, since plenty of fellows on here are running S300/S400 compounds on here and you are going to go that route eventually. bgilbert ran that on his 550hp truck as a top unit, although I am not sure on the specific size of it.
Postby JQmile » Tue Feb 07, 2012 8:27 pm
Whatever's cheap. If you are going with big sticks and twins in the future, spend your money on that.
JQmile
Postby oldestof11 » Wed Feb 08, 2012 5:19 am
What is the overall hp goal? What size S400? There is science behind this people, not picking the flavor of the month.
Postby ahale2772 » Wed Feb 08, 2012 9:03 am
Jon is right, most of those turbos would require a decently small s400 to do well in a set of twins. there truly is no single turbo to rule them all.
I would suggest a s363/68/.91 twinscroll
might be a bit big for non Ic sticks, but it would pair up well with a s400 down the road with an external gate or two
Postby oldestof11 » Wed Feb 08, 2012 3:21 pm
A 63 in our boats would be good for mid range and top end but be laggy on the bottom with out at least a cam.
If it is an all around truck, a he351 or s300g 57mm with a 472 would be good. Enough air for top end, not a lot of low but better than a 63.
That is, if you want a pick from your list.
Postby AHineman » Wed Feb 08, 2012 3:32 pm
S300G over S471 or S475 are a nice setup for relatively cheap.
Postby ford69557ci » Wed Feb 08, 2012 5:29 pm
I would go with the he351cw. there are a few guys making 700hp when coupled with something like an ht4c. I have seen a few commonrail trucks around here do righ at 500whp with an he351cw with modded waste gates.
ford69557ci
Postby fatstack » Wed Feb 08, 2012 7:15 pm
I just plan on a box stock, i believe a 74 mm s400 from a vendor and maxed 12 mm ve, no spray, non i/c setup retaining the manual transmission
fatstack
Postby fatstack » Wed Feb 08, 2012 7:17 pm
Thats definitely a little ways down the road tho.just stock sticks and single turbo for now. Mainly want a happy medium between spool up and egt control in both setups.
fatstack
Postby ford69557ci » Thu Feb 09, 2012 4:46 pm
an he with a s475 would make a killer set of fast spool twins
ford69557ci
Postby shiftycapone » Wed Feb 15, 2012 7:17 pm
Small turbine on your s400 primary will be beneficial.
I'd go with the he351, because it is cheap. I have ran an hx35 as a secondary and thought it performed well also.
And there is a .83 housing for the 63/68 turbo that has not been mentioned.
1990 D250
shiftycapone
Postby cougar » Sat Feb 18, 2012 11:57 am
oldestof11 wrote:What is the overall hp goal? What size S400? There is science behind this people, not picking the flavor of the month.
No truer words have been spoken. This goes for any other performance part as well. They all have to support one another in order to perform correctly. A street racer and a tow pig have different requirements, so you have to set a specific goal and part toward that goal and forget the rest.
I have a pile of parts to prove it. :oops:
01 2500 "the work truck".
cougar
Postby fatstack » Tue Feb 21, 2012 7:09 pm
So I have in hand an he351cw :D. Should i b able to stay on top of it ( in the power) with my stock injectors?
fatstack
Postby cougar » Fri Feb 24, 2012 9:40 am
HE351CW has a waistgated 9cm2 turbine housing. Even with an intercooler I'd be worried about the EGT.
cougar
Users browsing this forum: No registered users and 67 guests
