My injectors
My injectors
Postby 92d250 » Thu Oct 23, 2008 11:19 pm
Well i am getting some injectors. They are 6x16's and im wondering how much smoke and power these will make with whats in my sig? im going to add a hx40 really soon also. And how much of a gain are these gonna make?
Thanks
1992 D250 370,000 and counting on the cummins, auto, pump turned up, 6x16, 3200 spring, afc lever mia, boost and pyro guage, single stack, 5 inch lift, shifter with od button on it, potentiomitor..... Next hx40, 285's...
92d250
Postby cummins king » Fri Oct 24, 2008 5:28 am
you will probably melt the turbo.
93 4X4 auto
cummins king
Re: My injectors
Postby Ace » Fri Oct 24, 2008 7:05 am
92d250 wrote:... im going to add a hx40 really soon also.
It would be a good idea to add the HX40 at the same time.
Ace
Postby Philip » Fri Oct 24, 2008 7:49 am
If your not on a first name bases with the local smoke nazi's right now. You will be soon. With all your pump mods your going to make a lot of smoke if your on the throttle much.
If you have the stock converter in the truck it isn't going to like those injectors eather.
That HX40 might be a little small with the 60MM intake wheel. A 64 or 66 might be a better idea.
Postby 92d250 » Fri Oct 24, 2008 10:35 am
Ok what turbo should i look at getting with these? I can get the hx40 for 200
92d250
Postby 1991cummins » Fri Oct 24, 2008 10:07 pm
that is a good price if your looking at the right turbo.
alot of people on here like s300's... but for 6x16's i would say you would want a big custom or something, with like what philip said a 64 or 66 compressor wheel... alot of people run a solid set of twins with those injectors. they are really big hot injectors
1991cummins
Postby 92d250 » Fri Oct 24, 2008 11:07 pm
Im wondering if a hx50/55 will work?
92d250
Postby cummins king » Sat Oct 25, 2008 8:59 am
The hx50 is more like the turbo for those injectors it will be a bit laggy but hold on when it biulds Boost
93 4X4 auto
cummins king
Postby CumminsPride » Sat Oct 25, 2008 9:48 am
I think an HX50 in a 19cm housing on a Big Foot manifold with some juice would make a sweet charger for an auto truck.
06 3500 AT Mega Cab SRW 4X4
CumminsPride
Postby Begle1 » Sat Oct 25, 2008 10:09 am
What's a Big Foot manifold?
A manifold with a T4 flange on it?
Postby CumminsPride » Sat Oct 25, 2008 10:13 am
Yes, made by ATS known as the "ATS Big Foot".
CumminsPride
Postby 92d250 » Sat Oct 25, 2008 11:51 am
what size is the hx50?
92d250
Postby CumminsPride » Sat Oct 25, 2008 12:13 pm
It has a T-4 foot, I believe it's a 64mm compressor. I have no idea what the exhaust wheel is??
CumminsPride
Postby 92d250 » Sat Oct 25, 2008 12:15 pm
would it be laggier that the 21 i have stock? and what kind of boost numbers would i see?
92d250
Postby KTA » Mon Oct 27, 2008 6:23 am
On my truck the hx50 was a lag pig. My 62/71 S300 would stomp it into the ground in performance. Personally I like rolling into the throttle and feeling the torque, not dropping gears like a gasser to pass to get the turbo lit. :roll: The S300 also made more hp and torque than the HX50 and it was in the 16cm Pro 52 housing.
