Timing Advance Spacer...
Re: Timing Advance Spacer...
Postby Tsbourne09 » Mon Mar 26, 2012 11:50 pm
Remps wrote:With 7x15 injectors I'd personally try it without retarding the timing.
Whats a good sign of to much timing?
Not On Yet: 60#VS
Tsbourne09
Postby Tacoclaw » Tue Mar 27, 2012 6:33 am
Your 7x15 injectors are almost twice the size of my 5x14s. They're probably not that far off of a 6x16, which is an injector you just don't run with an HX35.
No amount of timing is going to cut your smoke and heat to manageable levels.
Postby tampabayBill » Tue Mar 27, 2012 6:52 am
X2, you are past due for a turbo upgrade.
Twins coming soon!
tampabayBill
Postby Remps » Tue Mar 27, 2012 12:09 pm
If it sounds like a bagged out 6.5 chevy cold starting in -20, back the timing off a bit. :lol: I'd be careful with the head gasket with the added timing as well. Probably be a good idea to at least drill/port the wastegate on that HX35, keep it alive a little longer. I'm gonna do mine next week hopefully, thinkin of goin with a 13/16 bit, and notch the backplate a bit so the flapper can open a bit further.
Postby Tsbourne09 » Tue Mar 27, 2012 9:27 pm
I know im in desperate need of a larger turbo. Im going to get a larger turbo and 47rh soon as soon as funds and deal comes by. Just trying to do all i can on the small stuff for now...
Not On Yet: 60#VS
Tsbourne09
Postby Tacoclaw » Wed Mar 28, 2012 6:34 am
I know it sucks to hear this, but your best mod may be to turn your fuel screw down a couple turns. You probably won't miss too much, as over-fueled as you are.
Postby Tsbourne09 » Wed Mar 28, 2012 11:53 pm
I know i will benifit from turning it down but its just so hard to lol. Thanks.
Not On Yet: 60#VS
Tsbourne09
Postby The_Head » Thu Mar 29, 2012 7:25 am
Do it. Don't be one of those diesel ricers that runs around with too much fuel and not enough air. It's all too easy with our trucks.
The_Head
Postby Farmboy92_2009 » Thu Mar 29, 2012 11:03 am
so with running an 1/8 bump already whats this timing spacer gna do for me? the plan for the truck is a set of 5x14's or a set of 7x14's and a screamin eagle 63mm or a similar 64. thanks tater
Farmboy92_2009
Postby bmoeller » Sun Apr 08, 2012 10:59 am
Could probably pull the timing back to stock and run the spacer.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby Farmboy92_2009 » Sun Apr 08, 2012 1:46 pm
is it not smart to run em both at the same time?? i know of atleast one that has his to the head and was ALSO running the spacer and said when he dropped the timing on the pump that he swears he lost 50-80hp...?? curious i guess. timing is a good thing to an extent..
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby Tacoclaw » Sun Apr 08, 2012 2:04 pm
He just said you could, not that you should. It's all about where in the RPM range you want to make your power. Bumping your static timing will shift the powerband higher up in the revs. The spacer makes it so you don't have to bump it so much to let the pump keep up with the advance needed in the higher RPMs. Horsepower isn't everything, and if you only change your timing then you're just trading torque for it.
Users browsing this forum: No registered users and 75 guests
