another 14mm pump
Re: another 14mm pump
Postby ahale2772 » Thu Oct 13, 2011 4:22 am
Yeah Mark, your right the vane pump is the bigest limitation to flow.
thats why other inlets would be good (IMO). KTA didnt dual feed his pump because he had nothing to do :grin:
with big injectors and a 14mm head, case PRESSURE is important otherwise the h&r will seize, dosnt matter what kind of volume you have because the little inlets on the VE are going to need pressure to squeeze fuel in.
I aim to try a dual feed setup, in retrospect I sould have snagged that 14mm head :(
Postby DLittle » Thu Oct 13, 2011 7:45 pm
firstgennutty wrote:so I just picked up a 14mm head
from what i read so far it takes big injectors and higher pressure/loctite seal
so what fass, airdog/raptor are you guys using i was told to run 45psi but almost everyone i find online is limited at 30 psi?
for bigger lines what are you guys doing on the tank tide? as far as pick up goes
injectors....read that 6x18 were the minimum? true or what
anyone run the 14mm with the afc still? most i see read are either afc deltes or the arm is cut/removed? i want to drive mine too not just dyno/race
thanks
Let me know how the 14mm works out for you ? I wish I could have ran it. :( . Maybe next go round. On a side note I dont have a hood release cable. Have FUN !!!!
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby firstgennutty » Sat Oct 22, 2011 8:03 am
Will do still rounding up all the support parts still as well as brakes springs and bearings and shims for the transmission
firstgennutty
Postby f100 cummins » Mon Dec 05, 2011 7:54 am
sorry to jump in but what are the thoughts on the rocken tech 14mm head?
1965 f100 with a firstgen 5.9 ,7x15 sac injectors, maxed ve with a denny t afc delete, all 8 an fuel line ,aeromotive a1000 lift pump, hamilton valve springs and pushrods,m&h timing spacer , h1c with 60 mm, new 727 with a manual valve body and hd flexplate, rci fuel cell and a winters quickchange rear 2.75 gears with all willwood brakes.
http://www.facebook.com/Whitetrashfabrication?ref=pb
f100 cummins
Postby ahale2772 » Mon Dec 05, 2011 7:56 am
its the only one out there, apparently Sheid uses those H&R's in their 14mm builds...no other choice
Postby f100 cummins » Mon Dec 05, 2011 8:03 am
thats my next step but no one really has any opinions about it (that i can find)
f100 cummins
Postby ahale2772 » Mon Dec 05, 2011 8:18 am
what kind of oinion do you want about it? there is tons of stuff mentioned about keeping them alive or not... big injectors, lots of fuel supply
Postby f100 cummins » Mon Dec 05, 2011 9:14 am
ive got more than enough fuel for that job with my a1000 it flows 400 + gpm i was curious about the driveability
f100 cummins
Postby KTA » Tue Dec 06, 2011 4:49 pm
It might be 400 gallons per HOUR but not per minute! lol
Postby ahale2772 » Wed Dec 07, 2011 5:02 am
LOL, tis why I left this thread alone, his a-1000 can move a swimming pool in about 25 minutes :lol:
Postby JQmile » Thu Dec 08, 2011 7:55 pm
f100 cummins wrote:ive got more than enough fuel for that job with my a1000 it flows 400 + gpm i was curious about the driveability
What do you want to know? Mine has a pretty healthy lope and haze at idle, but cleans up good at rpm and light throttle. Full throttle is night
time behind me without nitrous, but I don't have that much turbo either.
JQmile
Postby dazedandconfused » Fri Dec 09, 2011 6:33 pm
Your truck Jason would be a great one to data log and swap in a Hamilton 188/220 to see how it would help with your egt's and idle haze.
Postby f100 cummins » Fri Dec 16, 2011 8:53 am
i was just curious if i keep enough pressue to the pump and have big enough injectors will the pump live or will it eventually die
f100 cummins
Postby f100 cummins » Fri Dec 16, 2011 8:55 am
and yes per hour sorry
f100 cummins
Postby ahale2772 » Fri Dec 16, 2011 9:38 am
I agreed, Jason, you need to do a cam swap. it would be good for the magazine. 8)
Users browsing this forum: No registered users and 81 guests
