5x18s....
Re: 5x18s....
Postby 1bad93 » Wed Apr 11, 2012 12:25 pm
A few years back a buddy of mine ran 390hp on coaltrain 435s(5x14s) with maxed 12mm h1c with gds 60mm kit lplp and a built 47rh. I only know one person around me running 5x16 but I don't think he ever hit a dyno with it.
1bad93
Re: 5x18s....
Postby tampabayBill » Wed Apr 11, 2012 12:50 pm
I've got a bit more playing with the IP then plan to dyno, I'll post results and 487 on fuel and a single turbo is pretty damn good...............Bill
Twins coming soon!
tampabayBill
Re: 5x18s....
Postby tampabayBill » Wed Apr 11, 2012 12:59 pm
The 14mm pump is interesting but I worry about reliability as my truck is an every day driver that I plan to keep on the road til I die ( may not be that long, I'm pushing 66 ) and I tow quite a bit. Anyway if I knew the 14mm would hold up in everyday use I would go for it..........Bill
Twins coming soon!
tampabayBill
Re: 5x18s....
Postby JQmile » Wed Apr 11, 2012 3:32 pm
tampabayBill wrote:The 14mm pump is interesting but I worry about reliability as my truck is an every day driver that I plan to keep on the road til I die ( may not be that long, I'm pushing 66 ) and I tow quite a bit. Anyway if I knew the 14mm would hold up in everyday use I would go for it..........Bill
There are no complete assurances in life.....the 14mm has worked fine for me, and for all people that haven't tried to spin 4,000rpm sled pulling with it. In my opinion, sled pulling isn't for non-automatic VE's.....it is for streetable trucks, and in that case a 14mm doesn't need to spin 4K to go to the store. Even the Rocken Tech versions have lasted in big fuel-system trucks that have run big injectors. Even if they do go bad, it is at full fuel and max rpms, which isn't most of the time. I have taken 1,000 mile trips with mine with the assurance if the pump does go south, it is within my 200 mile AAA range, because I know when I am being an idiot! :D
JQmile
Re: 5x18s....
Postby Tacoclaw » Wed Apr 11, 2012 3:52 pm
I'd also guess that most aren't going for the 14mm because they just don't need it. Once you get to a certain level, sure it may be necessary. Until then, the good ol' 12mm does just fine.
Re: 5x18s....
Postby dazedandconfused » Wed Apr 11, 2012 4:30 pm
I plan to go 14mm and 5x18 or 5x20 when i start turning mine up.
Re: 5x18s....
Postby JQmile » Wed Apr 11, 2012 6:09 pm
dazedandconfused wrote:I plan to go 14mm and 5x18 or 5x20 when i start turning mine up.
Atta Boy!! Go get 'em! You're good for an easy 600-700rwhp if you have enough air :D
JQmile
Re: 5x18s....
Postby dazedandconfused » Wed Apr 11, 2012 6:42 pm
Ill have the HX35/40 Ht3b combo and a cam then to so should be decent on air. Need that dang money tree to grow.
Re: 5x18s....
Postby 1bad93 » Thu Apr 12, 2012 9:50 am
Well ever since me and you were talking about 14mm pumps at the xdp open house last year I've been putting alot of thought into doing it with mine. It should be here in the near future I hope.
1bad93
Re: 5x18s....
Postby TWorline » Sun Apr 15, 2012 6:46 pm
I have run a set of 5x18s for over a year, still need my pump refreshed so the HP is down from what it could be, it is 354HP and 749TQ with no AFC. It also hazes all of the time even at 70 plus according to Pete. ;-)
Tim Worline
http://www.CoolerTubz.com/
TWorline
Re: 5x18s....
Postby PToombs » Mon Apr 16, 2012 5:28 pm
No Tim, it's hardly noticable, coughcough, hackcough. :lol:
Re: 5x18s....
Postby 1bad93 » Wed Apr 25, 2012 7:41 pm
Well just pulled the trigger on a set of 5x18s, ill make sure to report back when ever my heap gets back on the road.
jon
1bad93
Re: 5x18s....
Postby ahale2772 » Thu Apr 26, 2012 6:35 pm
Im thinking about going 5x20 when I finally get the time to build my self a 14mm pump...
I think there is lots to do with cylinder head flow that compliments injector choice.... but who knows
Re: 5x18s....
Postby soggy » Sun Apr 29, 2012 2:44 pm
I run 5x18s, It hazes bad at an idle and a 63/68 doesn't clean it up at WOT. Still have a 12mm and haven't dynoed or raced it yet.
Edit. I should mention that the lowered compression contributes to the haze.
92 W250 VE Powered
13.31@ 98.92
1993 D350 Tow Rig
soggy
Re: 5x18s....
Postby JQmile » Mon Apr 30, 2012 10:39 pm
Me too.....I ran 6x16s with no haze. Then with a .020 head gasket and an Air Dog 165 at 30psi, I had a haze. But it was still worth it :lol:
JQmile
Users browsing this forum: No registered users and 68 guests
