tampabayBill wrote:The 14mm pump is interesting but I worry about reliability as my truck is an every day driver that I plan to keep on the road til I die ( may not be that long, I'm pushing 66 ) and I tow quite a bit. Anyway if I knew the 14mm would hold up in everyday use I would go for it..........Bill
dazedandconfused wrote:I plan to go 14mm and 5x18 or 5x20 when i start turning mine up.
JQmile wrote:tampabayBill wrote:The 14mm pump is interesting but I worry about reliability as my truck is an every day driver that I plan to keep on the road til I die ( may not be that long, I'm pushing 66 ) and I tow quite a bit. Anyway if I knew the 14mm would hold up in everyday use I would go for it..........Bill
There are no complete assurances in life.....the 14mm has worked fine for me, and for all people that haven't tried to spin 4,000rpm sled pulling with it. In my opinion, sled pulling isn't for non-automatic VE's.....it is for streetable trucks, and in that case a 14mm doesn't need to spin 4K to go to the store. Even the Rocken Tech versions have lasted in big fuel-system trucks that have run big injectors. Even if they do go bad, it is at full fuel and max rpms, which isn't most of the time. I have taken 1,000 mile trips with mine with the assurance if the pump does go south, it is within my 200 mile AAA range, because I know when I am being an idiot!
soggy wrote:
Edit. I should mention that the lowered compression contributes to the haze.
