dont want to pop the head gasket
Re: dont want to pop the head gasket
Postby rockmike » Mon Feb 04, 2013 4:06 pm
So I crawled under there and pulled off the WG actuator and extended the rod a sqeek past 1/8" and reinstalled.Gave the truck a nice warm up and went for a FLOG run :mrgreen: No W/M I get 31 psi max and settles down to about 29 psi...before it would boost up to 34 lbs.
With W/M the boost hits about 36-37 psi for just a split second and settles down to 32 psi WFO.
Runnin up a small hill The boost held steady at 32-33 psi (W/M on) at 3200 rpm,sucked the fuel press gauge down to 7 psi, temp hit 8k post turbo and was climbing but climbing very slow,I was hittin close to 100 mph at that point and got out of it.
Im going to retorque the head bolts tonight just to be safe...y'all think I should retorque hot or cold?
Thanks!
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Postby RCCUMMINS89 » Mon Feb 04, 2013 4:09 pm
ARP says do only cold torques with their head studs..... So I say cold, lots of people will argue.
Postby rockmike » Tue Feb 05, 2013 10:02 am
POP! goes the head gasket! yup 300,000 miles and hot roddin the poor thing took out the head gasket...huh?!
I got 7 weeks before I head down to MOab,Utah.I only work 62 hours a week lol every damn week!
I need to get me a reman head and a gasket set,aint got time to be haulin stuff back and forth to the machine shop,besides I would like a nice new ported head to put on her so I can take out the bottom end! lol
You guys got any suggestions where I find a good head ready for install?
Thanks.
rockmike
Postby RCCUMMINS89 » Tue Feb 05, 2013 11:05 am
I have a good spot where you can have some port/polish work done.
As of right now DAP sells the cheapest studs at $420???? IIRC.
Postby skilletky » Tue Feb 05, 2013 12:28 pm
you can get a head from cheap to expensive on ebay. i got a good used head and rockers for 200 off ebay. had the head cleaned, decked, and oringed and rockers milled. then gathered all the parts. took a day off work and got everything put on. i got a set of new arp studs for 399 of ebay also.
skilletky
Postby RCCUMMINS89 » Tue Feb 05, 2013 1:03 pm
Yep... I got studs for $420, and was in my head (re surfaced, magnafluxed, new valve guide seals, and o-ringed) for $405... for another $650 I could of gotten it ported/polished.
Postby oldestof11 » Tue Feb 05, 2013 3:18 pm
If you truly need it, do a quick check with a machinist edge of the head. It might be good to go as is.
Postby RCCUMMINS89 » Tue Feb 05, 2013 3:25 pm
Ya...but at 300k miles I'd bet my arm that it's not gonna be within spec. Maybe though
