With W/M the boost hits about 36-37 psi for just a split second and settles down to 32 psi WFO.
Runnin up a small hill The boost held steady at 32-33 psi (W/M on) at 3200 rpm,sucked the fuel press gauge down to 7 psi, temp hit 8k post turbo and was climbing but climbing very slow,I was hittin close to 100 mph at that point and got out of it.
Im going to retorque the head bolts tonight just to be safe...y'all think I should retorque hot or cold?
Thanks!
