A few performance questions?
Postby Swaggs » Sat Nov 28, 2009 4:02 pm
Advancing the timing a little bit would be a good idea, I think.. but the upgrading the lift pump makes alot of sense to me. I think I will do that.. Maybe take my denny T out until I get a turbo and lift pump. I think a turbo, lift pump and injectors and I will be done.. we will see..
just blew out my shut off solenoid.. bummer
92 W250 CTD, Getrag, hx35, DiamondEye, Mostly Stock
89 Ramcharger 360/727
'92 W250 CTD, Lifted Sold
'96 2500 CTD Sold
Swaggs
Postby peobryant » Sat Nov 28, 2009 5:18 pm
Swaggs wrote:Advancing the timing a little bit would be a good idea, I think.. but the upgrading the lift pump makes alot of sense to me. I think I will do that.. Maybe take my denny T out until I get a turbo and lift pump. I think a turbo, lift pump and injectors and I will be done.. we will see..
I wouldn't take the DennyT cone out. I'd back out the power screw a little bit (it'll save you another shut off solenoid) until you get a turbo and injectors.
A piston pump is a very good upgrade. If you need installation help, I have a link that is very helpful. This picture shows everything you'll need, and the part numbers.
I'm not sure how accurate the part numbers are now.
Postby Swaggs » Sat Nov 28, 2009 7:14 pm
l really want to do the piston Lp. where can you still get the low pressure pumps?
'96 2500 CTD Sold
Swaggs
Postby peobryant » Sat Nov 28, 2009 7:17 pm
As far as I know, Cummins and Case are still the places to go for one. Case used to be cheaper, but when I checked a couple months ago, the Cummins unit was cheaper.
Postby 1STGENFARMBOY » Sat Nov 28, 2009 7:50 pm
I think a 2nd gen pump and regulator would be what you want, first it's about the same money, second a few more mods and you will still be able to pull the low preshure pump down, ask Richie. third i checked three months ago and the Case/IH dealer here was over $350 :shock:
Postby Richie O » Sat Nov 28, 2009 9:33 pm
Some of my issues of drawing down a low pressure piston pump may be my stock supply lines and pick up. I can draw it down to 3 psi. For sure it is way better then the wimpy diaphram. I only saw 3.5 psi with that and drew it down to 0 pretty easy. I am sure my 89 ( stock lp ) is pulling to 0 also ( gauge still on the dresser ).
Postby Swaggs » Sun Nov 29, 2009 6:59 am
i backed my starwheel out about a full turn to turn down the mid-boost smoke.. it seemed to help a little bit, until i put in the denny t. do you think if i turned the starwheel up a bit more it could actually get to the point where it is slowing down my spool up?
'96 2500 CTD Sold
Swaggs
Postby Richie O » Sun Nov 29, 2009 9:26 am
Swaggs wrote: do you think if i turned the starwheel up a bit more it could actually get to the point where it is slowing down my spool up?
On my M2 pin YES. It sure made it a dog with the starwheel up real hard. Almost made it hard to take off. Would mash the throttle and it was a turd. Once the pin dropped it was smoke city. :D In my case with the pin up there wasn not enough fuel to even think about building boost.
