putting in fuelpin need help
Postby Ace » Mon Jan 18, 2010 11:01 am
Boost pressure pushes the fuel cone down allowing the guide pin to travel up/out the ramp.
Ace
Postby stock91w350 » Mon Jan 18, 2010 11:28 am
cougar wrote:Something doesn't sound right to me here. Doesn't fuel pressure push the guide in out? Then the fuel pin acts as a stop based on boost. Given that, then the limit of the AFC lever travel is then a combination of the guide pin and the fuel pin. And the AFC lever in turn sets the governor position, along with throttle position which actually then controls the amount of fuel delivered. At least that is how I understand the system to work.
are you saying that the guide pin wont come in and out unless the engine is running and the afc unit is all together? and it is normal for the guide pin to stay in its hole if the afc cap is off the fuel pin out and engine off? thanks
91 w350 5spd dually. 5"stack, fuelpin, starwheel all in, smoke screw all in, homemade cold air intake
stock91w350
Postby stock91w350 » Mon Jan 18, 2010 11:58 am
ok guys, just got off the phone with BD diesel performance tech, he said the guide pin should come in and out when stroking the throttle linkage, he said if im looking down the afc and the pins not moving it is stuck and i should spray lube on it, hold the throttle wide open and tap the tip of the guide pin with a small screwdriver and if that works to lube it good while its out and work it back and forth. he also said after its fixed i should see more power and more smoke, yay! hope i can unstick it! me needum more power!
stock91w350
Postby Ace » Mon Jan 18, 2010 4:21 pm
stock91w350 wrote:... he also said after its fixed i should see more power and more smoke,..
Yeah, it's been my experience things always work better after they are fixed! :P
Ace
Postby stock91w350 » Tue Jan 19, 2010 1:59 pm
how slow and weak would my truck be with the guide pin stuck in? would it still be drivable? would it still get up to speed?
stock91w350
Postby Ace » Tue Jan 19, 2010 2:05 pm
I thought mine was pretty slow and weak when everything was operating perfectly at the stock settings right after I bought it. Then I started trolling these diesel web forums and it's been all uphill ever since.
Ace
Postby DennyT » Fri Jan 22, 2010 2:33 pm
The guide pin will get stuck at times. You have to get a small screwdriver, stick it down the bore and push the guide pin in manually. Youll be in bid'ness after that.
1992 Cummins Ext Cab 4x4 NV4500
DennyT
Postby stock91w350 » Sun Jan 24, 2010 3:50 pm
DennyT wrote:The guide pin will get stuck at times. You have to get a small screwdriver, stick it down the bore and push the guide pin in manually. Youll be in bid'ness after that.
I tried that and i tried a magnet but dident work, may i need to be a lil more ruff? do i push in on the head of the guid pin?, cause i think its already all the way in?
stock91w350
Postby dpuckett » Mon Jan 25, 2010 4:02 pm
Be ready to shut it off immediately, but you can turn the engine on with the fuel cone removed- the case pressure should push the pin out. If the pin is stuck, the truck will be a turd, as Richie so eloquently put it. It will run exactly as if you dont have the AFC hose hooked up. If the case pressure pushes the pin out, it will keep pushing it til the guide pin hits the backside of the "well", and also likely cause a small fuel leak. Kill the engine, spray the pin with your faovrite lube, and push it back in with a screwdriver. Work the throttle lever again (engine off) and see if it pops out.
Should the case pressure of the running pump fail to push the pin out of its hole, remove the throttle lever. Remove the hex head plug at th e front of the AFC housing, and push the AFC lever (behind the just-removed plug) toward the rear with a small screwdriver. That should pop the pin into the well. Repeat the lube process, and replace the assmeblies and parts removed.
Dan
Postby MMeier » Mon Jan 25, 2010 6:42 pm
[/quote]
Yeah, it's been my experience things always work better after they are fixed! :P[/quote]
Depends on what else you break while fixing the first part !!! :(
'93 W250CC, 5 speed, 3.54's, pump tweaks, NV4500 conversion, straight piped, 33's. Also, have '03 3500 QC 4WD dually, 551HP/ 1008 TQ @ MATS '07
MMeier
