Build plan?
Postby ryan10 » Thu Feb 14, 2008 5:07 pm
Ok, so how much power could i make with the 3200 spring, afc ground and a GDS compressor upgrade?
thanks
1993 w350 6" lift, 35" all terrains. fuel screw in as far as it will go, pump mods, bully dog injectors, bullydog fuel pin, 14cm wastegated housing, water/meth injection. Ground AFC foot, 3200 spring
soon to come: turbo upgrade.
ryan10
Postby DTanklage » Thu Feb 14, 2008 7:11 pm
that depends on how it is tuned and some other variables
what ex housing are you using?
is it waste gated?
one or both sides?
DTanklage
Postby ryan10 » Thu Feb 14, 2008 7:51 pm
the exhaust housing is a 14 cm wastegated on the exhaust side.
ryan10
Postby DTanklage » Fri Feb 15, 2008 12:31 pm
14 is a great housing for that thing
but you need to modify it so the pressure is relieved on both sides
DTanklage
Postby ryan10 » Thu Feb 21, 2008 8:55 am
Ok guys, i found a WH1e, wastegated. does this require a 4" DP? Im thinking this turbo would be good, as of yesterday i ground my AFC foot and installed a 3200 spring, and am now deffidently in need of a turbo.
thanks.
ryan10
Postby ryan10 » Sun Feb 24, 2008 6:31 am
ok guys, would this be a good hx40? the guy is local and i could go pick it up soon.
here is what he told me about it:
its the standard flange, what is that, the t3 i believe. as for the compressor wheel, i'll give you the model #. it came off an 8.3 l cummins motor. holset kit#3802256rx assy #3530994 ser# m872395. if i am interpereting the thing right. looks like a 56 wheel with what was a 22 t4 housing which i took off and switched over to a 18 t3 housing. the thing has no play and is in very good shape. i know they go for about 600 new, so 250 is good for me.
ryan10
Postby KTA » Sun Feb 24, 2008 9:32 am
An hx40 is a 60mm wheel, so its not as good.
Postby ryan10 » Sun Feb 24, 2008 9:33 am
Ok, well he told me the turbo is an hx40? so this would have the 60mm wheel? I googled the #s, and it looks like its an h1e Also, how will the 18cm housing be? i like my 14, but i dont like it at all on the highways, so i figure the 18 will be an improvement on the highway.
thanks.
ryan10
Postby KTA » Sun Feb 24, 2008 9:42 am
The h1e was the predecessor to the hx40, the 56mm wheel is most likely correct, and still to small to be worth the upgrade.
Postby ford69557ci » Sun Feb 24, 2008 2:31 pm
doesnt the hx 35 have a 56mm wheel?? or is it 58?
ford69557ci
Postby ryan10 » Sun Feb 24, 2008 3:01 pm
Ok thanks guys. I have another question. I scored a 2nd gen Piston lift pump for 30 bucks. When i install it, i want to run bigger rubber lines. I have heard of the glacier diesel big line kit from the fuel filter to the pump, but what can i run from the piston pump to the fuel filter?
thanks.
ryan10
Postby PToombs » Sun Feb 24, 2008 3:06 pm
Instead of rubber, use plastic. The air lines on big trucks is fuel resistant stuff. If I upgrade, that's what I'm going to use.
Postby TWorline » Sun Feb 24, 2008 3:30 pm
PToombs wrote:Instead of rubber, use plastic. The air lines on big trucks is fuel resistant stuff. If I upgrade, that's what I'm going to use.
and it comes in some cool colors as well. Pete, what happened to the sheep? Hmm there is some resemblance there...[img][img]http://i116.photobucket.com/albums/o28/DieselRam250/802d3f3c.jpg[/img][/img]
Tim Worline
http://www.CoolerTubz.com/
TWorline
Postby PToombs » Sun Feb 24, 2008 4:45 pm
That's an old one! :lol: Must be SOP 3, got the old box and no stacks!
Tim, I'm trying to get away from the sheep stigma! People keep asking if they can borrow 1! :shock:
Postby DTanklage » Sun Feb 24, 2008 5:15 pm
ryan10 wrote:
I scored a 2nd gen Piston lift pump for 30 bucks. When i install it, i want to run bigger rubber lines...
you cant put a 2nd gen lift pump on a ve with out a regulator
it has a 40 psi spring in it and that will blow the frt seal on the ve
DTanklage
