Ok, so how much power could i make with the 3200 spring, afc ground and a GDS compressor upgrade?
thanks
and it comes in some cool colors as well. Pete, what happened to the sheep? Hmm there is some resemblance there...[img][img]http://i116.photobucket.com/albums/o28/DieselRam250/802d3f3c.jpg[/img][/img]PToombs wrote:Instead of rubber, use plastic. The air lines on big trucks is fuel resistant stuff. If I upgrade, that's what I'm going to use.
ryan10 wrote:
I scored a 2nd gen Piston lift pump for 30 bucks. When i install it, i want to run bigger rubber lines...
Users browsing this forum: No registered users and 67 guests
