oldestof11 wrote:Put your timing back to stock-ish and put the spacer in. Should help low end spooling and keep you going in the top end. Then disconnect the KSB wire and put in your own switch.
The 63 is slightly on the bigger side for the injectors and the VE it seems.
Also, check your shut-off solenoid. When mine was going out on my 2wd, it didn't shut it off right away but it also didn't fully open. When I got a new one, some new SOTP power was found but I don't know if it was all in my head.
fatty wrote:Have you turned the full power screw? I don't see that in your sig... Also you could try a 374 or even a 354 spring (3700-3800, 4200 rpms).
fatty wrote:I just put in a 374 last night and ground my stock cone a little further. Spools better and hits 38-39 psi now on the stock injectors.
Jklawinsky wrote:Dang ol dodge, ain't it Ethan? Lol
Users browsing this forum: No registered users and 78 guests
