TheTowingCowboy wrote:I may just have my pump sent off. I assume the pump should be a good candidate since its only got 90,000 miles.
AHineman wrote:TheTowingCowboy wrote:I may just have my pump sent off. I assume the pump should be a good candidate since its only got 90,000 miles.
If you want to get every last cc out of it; but you can have it running like you wouldn't believe for a little time and about $13.
AHineman wrote:A few years ago, GLHS had different cam plates tested on the bench and the stock 2.8mm gave him the most fuel, but it was also at the lowest RPM.
Users browsing this forum: No registered users and 67 guests
