TheTowingCowboy wrote:I may just have my pump sent off. I assume the pump should be a good candidate since its only got 90,000 miles.
AHineman wrote:TheTowingCowboy wrote:I may just have my pump sent off. I assume the pump should be a good candidate since its only got 90,000 miles.
If you want to get every last cc out of it; but you can have it running like you wouldn't believe for a little time and about $13.
AHineman wrote:A few years ago, GLHS had different cam plates tested on the bench and the stock 2.8mm gave him the most fuel, but it was also at the lowest RPM.
