DD horsepower
DD horsepower
Postby 2wd_sled_puller » Mon Mar 02, 2009 7:32 pm
i just bought a 93 first gen and got a couple questions. Before i bought it i notice there was a little bite of water in the oil but hey for 258,000 miles and me paying 400 dollars for this old girl i couldn't pass this truck up. Where can i get the thicker head gasket and studs for this baby. Do yall have a part number
Next i will be pulling 20,000 pound regulary with this thing. I am going to have a fully built georend brothers tranny and problemy twins. can i make 500 hp out of this puppy and it still be reliable enough to pull that kinda weight?
Im new to the first gen but not new to the diesel's
The HULK 1993 dodge cummins Afc work. Screw turned to runaway. Ht3b turbo looking for sticks
Piper 1997 chevy 2500 vortech 350 soon to be vortech 383
2wd_sled_puller
Postby peobryant » Mon Mar 02, 2009 7:42 pm
500rwhp will not be reliable at all, especially for towing. In my opinion, a very good tow rig would have 325-350rwhp. It will have all the power you will need, and still be very reliable.
Also, if you are going to use it solely as a tow rig, and want to keep an auto tranny, you may want to look into a 47RH, from the '94-'95 2nd Gen trucks. The addition of a lockup converter will really help with towing, and there is a lot of aftermarket support for that tranny. For either tranny, Dave Goerend is the guy you want to go to though.
Postby 2wd_sled_puller » Mon Mar 02, 2009 7:59 pm
'91 Cummins wrote:500rwhp will not be reliable at all, especially for towing. In my opinion, a very good tow rig would have 325-350rwhp. It will have all the power you will need, and still be very reliable.
Is the tranny thats in my 93 the 727 how do i check. Ive heard the the 93 is a new tranny with OD. Im thinking about putting a Nv4500 behind this thing. I can get 350 hp just by doing pump work and injectiors can't i?? The turbo will just be a add on i want twins to keep egt's around 900 to 1,000 on hard pulls
2wd_sled_puller
Postby Richie O » Mon Mar 02, 2009 8:11 pm
The tranny in the 93 should be a A518 4 speed overdrive. 900 degrees on a hard pull with 350 hp. I wish you luck.
Postby 2wd_sled_puller » Mon Mar 02, 2009 8:55 pm
Richie O wrote:The tranny in the 93 should be a A518 4 speed overdrive. 900 degrees on a hard pull with 350 hp. I wish you luck.
Thats why im thinking Twins are in my furture
2wd_sled_puller
Re: DD horsepower
Postby 2wd_sled_puller » Mon Mar 02, 2009 9:20 pm
Extreme_first_gen wrote:i just bought a 93 first gen and got a couple questions. Before i bought it i notice there was a little bite of water in the oil but hey for 258,000 miles and me paying 400 dollars for this old girl i couldn't pass this truck up. Where can i get the thicker head gasket and studs for this baby. Do yall have a part number
Bump
2wd_sled_puller
Postby pulltilbroke » Mon Mar 02, 2009 9:28 pm
The part no# for the .020 gasket is 3283339 :D
Postby 2wd_sled_puller » Mon Mar 02, 2009 9:33 pm
pulltilbroke wrote:The part no# for the .020 gasket is 3283339 :D
Thank are these .020 gaskets the thick one's that people talk about??
2wd_sled_puller
Postby pulltilbroke » Mon Mar 02, 2009 9:45 pm
Yep, That part no# is burned into my brain :lol:
Postby 2wd_sled_puller » Mon Mar 02, 2009 10:03 pm
pulltilbroke wrote:Yep, That part no# is burned into my brain :lol:
lol thanks bud
2wd_sled_puller
Postby Begle1 » Mon Mar 02, 2009 10:47 pm
It's a .020" OVER headgasket that's the popular one, right?
Postby pulltilbroke » Mon Mar 02, 2009 11:09 pm
Yes, .020 overthick
Postby peobryant » Tue Mar 03, 2009 2:23 pm
You can probably get the gasket from Cummins, but if you can't here is a link to where you can.
http://www.puredieselpower.com/catalog/ ... -1055.html
Postby PToombs » Tue Mar 03, 2009 6:13 pm
$130 ? Ouch! :shock:
Postby pulltilbroke » Tue Mar 03, 2009 6:42 pm
The last one I got from Cummins Central power was 96$
