DCP 275HP injectors??
Postby jb » Thu Apr 23, 2009 2:09 am
Has anyone had any experience with DCP 275HP injectors??
I was also looking at their pumps as well but I'm open to sujestions.
( I have a 0 460 426 114 pump)
I'm looking for 275-300HP mostly for towing 10k trailers, any sugestions on turbo upgrades ect are welcome.
1990D250 /D60&80 3:54 gears /nv4500 /4" exhaust
jb
Postby Firstgen1 » Mon May 04, 2009 5:51 pm
i dont got no experience with them but i would go with new era 370 for a good cheap injector, or dinomite diesel stage 4
as far as the pump if its not wore out i would just turn rhe screw in a little
pdr diesel has good turbo upgrades, theyre cheaper than a hole turbo.
the last thing i would do is intercool it
i would get boost and pyrometer guages if you dont already have them
someone else can fill you in more
1993 w250 pin ground, 3 turns on fuel screw, starwheel maxed, custom intake,4in exhaust, guages, 16cm housing, piston lift pump, dtt converter, shiftkit, 35 psi of boost
Firstgen1
Postby peobryant » Mon May 04, 2009 5:55 pm
New Era 370's, an HX40 (or S300), a piston lift pump, and an intercooler. A better clutch might be in order as well.
Postby Richie O » Mon May 04, 2009 6:00 pm
275 to 300 on a stock clutch is fine. Pete ran his 388 dyno with a stock clutch. He had to change it because he was rough with it. My 93 must be atleast 275 and the stock clutch will hold it. I don't slip or ride the clutch.
Postby peobryant » Mon May 04, 2009 6:09 pm
Richie O wrote:275 to 300 on a stock clutch is fine. Pete ran his 388 dyno with a stock clutch. He had to change it because he was rough with it. My 93 must be atleast 275 and the stock clutch will hold it. I don't slip or ride the clutch.
I was under the impression that it will have a 10K trailer behind it most of the time. I know a stock clutch can hold 300rwhp of just puttering around town, but I would think a better one would be in order for towing 10K all the time. :scratch:
Postby Richie O » Mon May 04, 2009 6:12 pm
Better,, for sure. Im cheap. :D
Postby gear jammer 91" » Mon May 04, 2009 7:26 pm
You can get 300 hp out of your stock injectors pretty easy. If you are going to be towing 10K at that power level you WILL need to add an intercooler to keep things cool, and probably a better turbo. I would spend my money on those two things first. I'm still running stock non-intercooled sticks, my HP is in my sig.
01 LB7
gear jammer 91"
Postby DTanklage » Mon May 04, 2009 7:42 pm
first thing i would do is put a gov spring in it
if you are gonna follow their rec (ddp 3 or 4) and tune the pump you are prolly gonna overshoot your goal and will have to put a clutch in it
i think a hx-35 (54mmx58mm) works better than anythng at 300 hp
i just sold my injectors but have a aftermarket clutch and a 35 i could sell ya if you are interested in good used parts
make it a great night
don
DTanklage
Postby peobryant » Mon May 04, 2009 8:38 pm
gear jammer 91" wrote:You can get 300 hp out of your stock injectors pretty easy. If you are going to be towing 10K at that power level you WILL need to add an intercooler to keep things cool, and probably a better turbo. I would spend my money on those two things first. I'm still running stock non-intercooled sticks, my HP is in my sig.
It is my understanding that in a tow rig, you don't really want to mess with the pump too much. EGT's get out of control too fast with the fuel screw turned.
Yeah, throw a 366 sring at her too.
Postby dpuckett » Tue May 05, 2009 10:34 am
Depends on the turbo. My 91 had a PDR HX35 and it stayed within reason, towing and empty. It DID get hot at about 75mph outside Springfield MO one time, towing Bill's donor rig, but that was also about 2800rpm, 40psi boost- out of the turbo map. The 91 had spent its entire life pulling either a 40ft gooseneck w/tractors, or a 4-horse trailer with a rather large living quarter the 250K before I got it.
Get some guages, like mentioned, but add fuel pressure to the list. I know in an IC truck, the diaphragm is marginal on a stock truck, bet it's about the same with the bigger sticks in a nonIC truck.
Get your injectors checked, and see where they're at.
You're on a good track with the D80 and 4" exhaust. Opinions vary on the NV4500, so I wont go there.
Postby DTanklage » Tue May 05, 2009 11:40 am
it stayed?
DTanklage
Postby gear jammer 91" » Tue May 05, 2009 5:52 pm
If you add fuel, either with injectors or with the fuel screw it's gonna get hot. More fuel is more fuel.
01 LB7
gear jammer 91"
Postby peobryant » Tue May 05, 2009 6:06 pm
gear jammer 91" wrote:If you add fuel, either with injectors or with the fuel screw it's gonna get hot. More fuel is more fuel.
Philip tows with his 6X.018's and HX40. but he has stock pump settings.
Postby DTanklage » Tue May 05, 2009 7:08 pm
i wonder if jb, when he saw the ad for the 275 horse injectors, thought that meant you end up with 275 hp
as in total
at the rear wheels
if so jb you are very mistaken - those are supposed to produce 275 hp above and beyond stock
whats a stock first gen make anyways? gotta be close to 100 hp
lol
DTanklage
Postby jb » Tue May 05, 2009 7:54 pm
Hi guys
I'm looking for about 275-300HP total, honestly I was pretty happy with the stock truck with just the few mods I did (4" exhaust, gauges, pump turned up two turns) I did notice that the truck runs out of breath on the top end so the only other thing I really wanted was a bigger turbo.
To be clear, I have:
4" exhaust
new nv4500
Sachs(spelling?) 13" clutch
dana 80 (power lok) 3.54 gears
pump turned up 2 turns
I'm going to do:
Gear Vendors splitter
"366" spring
fuel pressure gauge
intercooler
1480 U joints (rear)
turbo upgrade
A question for all........
If I send out my injectors to have them checked/fixed who should I send them to???
Can I send them my pump as well???
Thanks
JB
jb
Users browsing this forum: No registered users and 85 guests
