Richie O wrote:275 to 300 on a stock clutch is fine. Pete ran his 388 dyno with a stock clutch. He had to change it because he was rough with it. My 93 must be atleast 275 and the stock clutch will hold it. I don't slip or ride the clutch.
gear jammer 91" wrote:You can get 300 hp out of your stock injectors pretty easy. If you are going to be towing 10K at that power level you WILL need to add an intercooler to keep things cool, and probably a better turbo. I would spend my money on those two things first. I'm still running stock non-intercooled sticks, my HP is in my sig.
dpuckett wrote:
My 91 had a PDR HX35 and it stayed within reason, towing and empty.
gear jammer 91" wrote:If you add fuel, either with injectors or with the fuel screw it's gonna get hot. More fuel is more fuel.
