There's a supercharger kit for our trucks?
Re: There's a supercharger kit for our trucks?
Postby oldestof11 » Mon May 07, 2012 4:49 pm
TheTowingCowboy wrote:Well my point is that if you feed something 1 gallon of fuel an hour theh ramp upt he pressure to deliver 2 gallons of fuel per hour but dont have enough fuel its useless. Hence why a atmosphere turbo is bigger so that it can make sure the small has enough air.
But still compounding a bigger turbo to a super to the engine seems like it would be the easiest way to go.
Point 1: I understand where you are coming from now. However, the point of the small ramping up the pressure of the big, is not really what it is needed for. Typically, it is flowing 1/2 the CFM of the big one.
Point 2: It has been tried and became a choke point. The reason being the bypass (pop) valve not being big enough to flow the CFM needed to drop the pressure to a safe zone for the supers rotors. Once a bigger bypass was put in (BOV I think they used), it was too quick of a drop in pressure.
Postby TheTowingCowboy » Mon May 07, 2012 6:06 pm
Well I thank you for the explanation. So I now understand how it could work but there would be a PSI limit, but still it is nice to get a full explanation
Thank You!.
TheTowingCowboy
Postby dazedandconfused » Mon May 07, 2012 6:10 pm
They are not solely using the bypass in the super to draw air. The setups I've seen recently have another roughly 2" pipe coming from your filter intake with a throttle body type setup feeding to the inlet bos on the turbo. Its controlled by a waste gate actuator like on a hy35 or hx35. You hit 20psi from the super the other gate starte to crack open. By 25 psi its wide open allowing a clear alternative path for the turbo to draw air and not being chocked by the super. So the super is running full song at 25 psi the turbo is starting to or singing already and the valve opens allowing more air to be sucked in. There are videos on YouTube of similar setups over sees on imports they daily drive. The whole point of a super/ turbo setup like this is to hive you snappy bottom end and a strong topend without sacrificing drivability.
Postby dazedandconfused » Mon May 07, 2012 6:13 pm
http://m1241.photobucket.com/albumview/ ... 1&newest=1
if this works you can see what im talking about in the video.
Postby The_Head » Mon May 07, 2012 6:14 pm
dazedandconfused wrote: The whole point of a super/ turbo setup like this is to hive you snappy bottom end and a strong topend without sacrificing drivability.
It must be even better than properly sized and tuned compound setup then?
The_Head
Postby dazedandconfused » Mon May 07, 2012 6:16 pm
You always have boost. From what ive read its usually 5 psi at idle and climbs fast. I like the idea of fueling hard down low and cleaning it up fast.
Postby ahale2772 » Tue May 08, 2012 4:49 pm
he said he was under driving the pully alot once he realized that he didnt have to suck through the blower all the time, hence, he knows that eventually the charger is doing all the work, but 5;bs of boost at idle gives any diesel a good start
Postby TheTowingCowboy » Tue May 08, 2012 7:29 pm
THis is just being out there but would a 871 or even a 1271 allow enough air flow? Just a thought. Lol be a lot of fab work but would be cool.
TheTowingCowboy
Postby Farmboy92_2009 » Tue May 08, 2012 9:33 pm
i should buy that kit :( i want it soo bad....lol
92 - SOLD. new ride.... 96 CC LB Dually 4x4 auto - Goerend's TD Convertor & HD VB, Autometer EGT/Boost/Trans Temp, 5'' TBE 6'' tip, #100 plate, II Dragonflow 5x.016's, CAI. Sitting in the shed - DDP 042 DV's, 80'' long Trac Bars, and nice purdy Full Replacement Ranchand :) WTB - 4k GSK, 60 lb VS's, and a 64mm turbo.
Farmboy92_2009
Postby The_Head » Tue May 08, 2012 9:55 pm
The_Head
Postby Farmboy92_2009 » Tue May 08, 2012 9:57 pm
:lol: :lol: :lol:
Farmboy92_2009
Postby bmoeller » Wed May 09, 2012 2:19 am
The turbocharged 2cycle Detroit's don't even need the blower once the turbo builds boost. Know of several guys using them to power center pivots. They pull the blower off and add a block off plate. Use compressed air at starting, and when the turbo is lit, they cut the air off and the turbo does the job. The blower is a restriction at that point.
SOLD- '99 3500, SO CTD, 5spd
bmoeller
