A/R TO cm2 CONVERSION ??
Postby 92 D/UNIT » Mon Nov 26, 2007 8:14 pm
Does anybody know what the cm2 is on a exh housing with a 1.28 A/R ? this is a w/g k31 turbo that i picked up cheap and im trying to determine whether the exh housing is too big for a compound setup for the street.
thanks!
388/886
92 D/UNIT
Postby ford69557ci » Mon Nov 26, 2007 9:26 pm
if it is the wastegated k31 it is the same turbo that industrial injection uses in their towing twins kit. i have 3 of those laying around off of 60 series detroits. a k31 is also what the compressor side of aurora 5k is but the exhaust housing is different. i would also like to know if the is a way to convert a/r to cm2?
ford69557ci
Postby ford69557ci » Mon Nov 26, 2007 9:39 pm
6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
i dony know how they came up with this but its a start if any math people wanna keep goin with the conversion
ford69557ci
Postby ford69557ci » Mon Nov 26, 2007 9:44 pm
looks like for every one cm2 the a/r goes up .08??? thats my take anyway buy i suck at math
ford69557ci
Postby ford69557ci » Mon Nov 26, 2007 9:56 pm
6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
13 cm2 = 0.97 A/R
14 cm2 = 1.05 A/R
15 cm2 = 1.13 A/R
16 cm2 = 1.21 A/R
17 cm2 = 1.29 A/R
im tired of typin a/r and cm2 so someone else continue
ford69557ci
Postby 92 D/UNIT » Mon Nov 26, 2007 10:16 pm
I saw that on a ricer site but didnt think it was right. do you know if its the same for all turbo brands?
anybody know what the A/R is on the industrial injection k31?
388/886
92 D/UNIT
Postby ford69557ci » Mon Nov 26, 2007 10:27 pm
no clue my friends II k31 and the ones off of the 60 series detroit that i have look identical i know the outside if the housing is the same and according to detroit there was only one housing made for the k31 that was wastegated.
ford69557ci
Postby flashgordon » Tue Nov 27, 2007 7:03 am
ford69557ci wrote:6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
13 cm2 = 0.97 A/R
14 cm2 = 1.05 A/R
15 cm2 = 1.13 A/R
16 cm2 = 1.21 A/R
17 cm2 = 1.29 A/R
What is A/R?
the cm2 is a size or measurement.... or space inside a turbo housing?.........is the A/R a flow.......at a set pressure? .....................................................
What do the A/R letters stand for?
just kinda lost here and would like some help to figure it out. :wrench:
Flash
flashgordon
Postby 92 D/UNIT » Tue Nov 27, 2007 7:18 am
on some turbos there is a exh housing size such as a 12, 14, 16 or18.5. and some turbo manufacturers dont use that type of measurement they use A/R. and i know nothing about A/R.
Here is some reading.
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html#b
if you understand it, could you explain it too me in white mans terms? :lol:
388/886
92 D/UNIT
Postby flashgordon » Tue Nov 27, 2007 10:33 am
92 D/UNIT wrote:on some turbos there is a exh housing size such as a 12, 14, 16 or18.5. and some turbo manufacturers dont use that type of measurement they use A/R. and i know nothing about A/R.
WOW Grate read!!!!!!!!
I thing it's a bit over my head put i print it out so i can read it when i have more time............Thanks again for the link.
O and by the way A/R is the Air Radius ;)
EDIT: :bball: :hs: HOW ABOUT AREA/ RADIUS :oops: :lol:
Flash.
flashgordon
Postby DLittle » Tue Nov 27, 2007 3:25 pm
Brain,
Here's some info given to me from CityDiesel. Hope this helps.
jason
Full Member
Offline
Re: Hot Rod Detroit 60/K31
« Reply #1 on: March 14, 2007, 05:11:00 PM »
The turbo is wastegated at 34 psi
The compressor wheel dimensions are
3.937 / 100 mm back wall
2.795 / 71mm inducer
the turbine housing specs are
24.92 cm
It is a pretty large turbo, but faster spooling than some common turbos used in twins. It will spool faster than an ht3b but will also support slightly less horsepower...
Dana
1992 W250 auto, 290 k, stock for now SOLD
1973 W100 SWB, D70,D60, 5.9 Twin Turbo SOLD
1993 W250 193k, Auto, TOTALED 10/30/2009
DLittle
Postby 92 D/UNIT » Tue Nov 27, 2007 4:20 pm
thanks Dana, so basically about 25 cm2 exh housing. mine is the garrett version of the k31. do you think it matters? was that for the 1.28 a/r?
388/886
92 D/UNIT
Postby ford69557ci » Tue Nov 27, 2007 5:22 pm
the detroit ones i have are wastegated and they say garret on them?
ford69557ci
Postby 92 D/UNIT » Tue Nov 27, 2007 5:25 pm
yep this came off of a Detroit. same turbo as what you have. do you have any with smaller exh. housings or are they only one size?
388/886
92 D/UNIT
Postby ford69557ci » Tue Nov 27, 2007 5:30 pm
the service and parts guys at detroit said that there is only one wastegated housing made for the 60 series. maybe garret makes some others that i am not sure of.
ford69557ci
