ford69557ci wrote:6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
13 cm2 = 0.97 A/R
14 cm2 = 1.05 A/R
15 cm2 = 1.13 A/R
16 cm2 = 1.21 A/R
17 cm2 = 1.29 A/R
im tired of typin a/r and cm2 so someone else continue
92 D/UNIT wrote:on some turbos there is a exh housing size such as a 12, 14, 16 or18.5. and some turbo manufacturers dont use that type of measurement they use A/R. and i know nothing about A/R.
Here is some reading.
http://www.turbobygarrett.com/turbobygarrett/tech_center/turbo_tech102.html#b
if you understand it, could you explain it too me in white mans terms?
