just completed a cam swap saturday and moved IP adv. 1 tooth and have the it bumped maybe 1/16" i was playing with the timing yesterday still wondering how everybody else gets there timing dialed in with out a timing light and if yall unplug the KSB solenoid or leave it for additonal timing
thanks to BC847 for the cam
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters Jeffery
smoke is gone and fuel screw is bottomed out and egts are about 750 800 WOT so i like quite abit im just kinda down on midrange to top end power thats why i was curious about the timing unless i just need a M3 and injectors ?
Which cam are you running? Along with which injectors? Stomp was kind enough to check my timing the other day with a light. It was no where near where I would have guessed. With it to the head at idle it was 14. With the ksb switched on I was at 21. This After I added a m&h spacer. After that experience of watching someone check my timing with a light, I think I'll give up on guessing hahaha. I was told a tooth is worth 10 degrees, so if I jump a tooth with my timing to the head I'd be at 24 degrees I suppose. Ksb might bring me up to 31! If my basic mathematics is on par.
Stomp used what looked like a digital timing light hooked up to this clamp looking sensor that went around the number one injector line. Quite simple. I'm sure you could buy the associated hardware to go along with a standard timing light. It might be something worth looking into. I'm actually kinda interested. He also marked Top Dead Center on my crank for future references. Who would of ever though a diesel guy would want a timing light???? Now that I'm thinking about it, a well informed one would.
That explains it. A buddy of mine has a 93' and with the pump turned all the way up and with a fuel pin, he could only hit a 1000 degrees. Thats a pretty good drop in temps. Then again any drop is a good drop when it comes to egts.
