timing
Re: timing
Postby directinjktn1stgen » Thu Sep 20, 2012 3:22 pm
yes reasons because i need more fuel mid range to top end power and it starts at the pump.... i tried to email them it said message failed tried it 3 times no luck at all lol maybe its just ment to be :bh:
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Re: timing
Postby Hansen01 » Fri Sep 21, 2012 9:28 am
some people say to just grind your stock one rather than paying $105,
i bought a denny T2 for mine and really liked it tho
Under construction...
Hansen01
Re: timing
Postby tampabayBill » Fri Sep 21, 2012 12:16 pm
Go on their web site and look for contact info and give them a call. Worked fine for me, they are easy to work with and good products.
Twins coming soon!
tampabayBill
Re: timing
Postby ellis93 » Fri Sep 21, 2012 1:01 pm
directinjktn1stgen wrote:yes reasons because i need more fuel mid range to top end power and it starts at the pump.... i tried to email them it said message failed tried it 3 times no luck at all lol maybe its just ment to be :bh:
I was responding to the don't waste money comment,I'd never waste time grinding one after buying my M2 pin. I like it fine and didn't want to try making the profile on the stock one.
Re: timing
Postby directinjktn1stgen » Fri Sep 21, 2012 3:11 pm
i was reponsding to the comment made by revemup15 ..... but ok ill give them a call thanks
Jeffery
directinjktn1stgen
