H1C parts
H1C parts
Postby Billy Bones » Sat Sep 22, 2012 2:25 pm
So I'm new here and trying to figure out how to search for things I hope I'm not duplicating things. I need parts for my H1C I don't know what the retainer washer is called but I found a kit on ebay that has it
http://www.ebay.com/itm/Turbo-Repair-Re ... %26ps%3D54
If there's a better place to purchase or from someone on the site I would appreciate the help thanks. I don't know how to post a picture here so if a pic would help let me know.
Billy Bones
Re: H1C parts
Postby cougar » Sun Sep 23, 2012 7:50 am
I get mine from these guys
http://gpopshop.com/
I buy only the complete kits when I do a turbo. If your going to do it, do it completely.
01 2500 "the work truck".
cougar
Re: H1C parts
Postby Billy Bones » Sun Sep 23, 2012 12:48 pm
Thanks for the site I like that they have the parts and pieces labled but that kit doesn't have the broken piece i need but I think that pic will get me closer to finding it thanks.
Billy Bones
Re: H1C parts
Postby Billy Bones » Sat Sep 29, 2012 1:53 am
Well I found a kit on ebay and rebuilt it yesterday I'm hoping I didn't throw it off ballance.
Billy Bones
Re: H1C parts
Postby GoldenRule » Fri Oct 05, 2012 9:25 am
Check these guys out for H1C parts, you can get exactly what you need or a complete kit for a good price:
http://baeturbosystems.com/servicekit4027309.aspx
They also sell a nice upgrade kit for the hx35 with a polished housing cheaper than anyone else I've found:
http://baeturbosystems.com/upgradekits-3.aspx
GoldenRule
Re: H1C parts
Postby Billy Bones » Fri Oct 05, 2012 10:54 pm
Thanks that's a great site!
Billy Bones
Re: H1C parts
Postby GoldenRule » Mon Oct 08, 2012 12:15 pm
Yeah, glad it helps. Seems like their rebuild kits are pretty good deal - $20-$25 less than other sites I've looked at. Bought my last kit from Gpop, but will try these guys next time.
GoldenRule
Re: H1C parts
Postby Mark Nixon » Thu Oct 11, 2012 12:18 pm
Billy Bones wrote:Well I found a kit on ebay and rebuilt it yesterday I'm hoping I didn't throw it off ballance.
Did you mark the turbine wheel to it's housing, then the compressor wheel to the back plate?
By doing it that way, you set the marks on the turbine side where they were, then simply line up the compressor wheel to the mark on the backing plate.
Easy as pie.
If you doubt it's in balance, make sure you grease or lube the center with oil, then set the turbo on a hard surface, preferably a heavy steel bench (DO NOT SECURE IT DOWN!), then blow compressed air into the exhaust housing.
If it chatters noticeably on the bench, it's out of balance, loosen the nut on the compressor wheel and move it around and re-tighten, then test again.
Generally, I've found that if it doesn't vibrate noticeably unsecured on a hard surface, the balance is "close enough".
Trust me, if it's out of balance, the turbo rattling, or humming, on the steel bench will tell you!
Re: H1C parts
Postby Exekiel » Fri Oct 12, 2012 6:04 am
What do You do if it is out of balance?
1993 f350 with a 5.9l ctd and getrag
Exekiel
Re: H1C parts
Postby Mark Nixon » Fri Oct 12, 2012 8:35 am
I haven't had one that wouldn't balance, but I'm told there are places that balance them for reasonable.
Contrary to what some believe, most of the more recent turbos are component balanced instead of assembly balanced, so chances are that they won't need to be re-balanced if they are dis-assembled.
If there is physical damage to the compressor wheel, it SHOULD always be replaced.
Re: H1C parts
Postby Billy Bones » Sat Oct 20, 2012 10:42 am
Looks like I will be putting my 3/4" steel table to good use soon. Thanks a ton for the help.
Billy Bones
Re: H1C parts
Postby Billy Bones » Sat Oct 20, 2012 10:45 am
Ha I just read your signature good one. Mark
Billy Bones
