opinions on welding the timing gear case ( damn pin )
Postby lopez dodge » Tue Oct 16, 2012 7:48 am
kdp got me . all gears are good no damage except crack in top of case. i have access to mig welder with spoolgun and aluminum wire. or should i just
start looking for "new" gear case ?
1991.5 ..getrag super40. 40,horse injectors,4"to 6" exhaust , bhaf 2nd gen intake,custom pin timed to the head ..1/4 14.9@93mph 5,500' with a little propane
lopez dodge
Re: opinions on welding the timing gear case ( damn pin )
Postby ellis93 » Tue Oct 16, 2012 9:38 am
Pics? How bads the cracks,or did it lay off a section? If its just cracks id drill the ends and find somebody with a tig set up to weld it. MIG welders like to leave pin holes in the aluminum if the person welding it isn't careful.
Postby lopez dodge » Tue Oct 16, 2012 10:20 am
didnt take any pics yesterday, try to get some today. the case is intact didnt knock a piece out just cracked clean trough.
looking on ebay i can find used case for about hundred buck or so, might do that instead of welding
lopez dodge
Postby lopez dodge » Wed Oct 17, 2012 7:19 am
damage was worse than i thought once i cleaned it up and got a better look[/img]Image[Image/img] will a case from 24 valve work? having hard time finding 12 valve gear case.
lopez dodge
Postby comotionman » Wed Oct 17, 2012 8:16 pm
if you can weld it so it fits properly without leaking I say go for it. looks like its all still there.
coupla trucks non & ic, 2nd gens, various other
comotionman
Postby lopez dodge » Thu Oct 18, 2012 6:12 am
i welded it yesterday . put cover on to keep case in shape.
made few passes , sealed it all back up :wrench: and drove to work this morning 8) got whole new respect for just how stout that 12 valve is.
pushing close to 500,000 mi at well above rated hp. and still more reliable than coworkers 6.0
lopez dodge
Postby 4thesporty » Thu Oct 18, 2012 9:13 am
Glad you got it fixed...just to answer an earlier question, no a case from a 24V won't work. You can find those for almost a dime a dozen because alot of people are Ppuming their 24V trucks.
You would have to find an IP specific case...VE, P7100, VP, whatever pump you have, that is the case you need.
1994 Chevy K3500 12V/NV4500
Full rebuild with mahle non I/C pistons, 370s (set @ 250 bar), HX35/HT3B, custom cam, studs and orings. Yep, it's a VE :)
Still in progress
4thesporty
Postby lopez dodge » Thu Oct 18, 2012 11:53 am
figured as much but finding timing case for 24v for like $35. figured i'd ask
lopez dodge
Postby Mark Nixon » Fri Oct 19, 2012 9:57 pm
I saw this too late, but I'll still make my comments.
With that much damage to the dowel pin, ALWAYS at the very least thoroughly inspect the pump gear's hub and keyway for cracking.
I had an engine, a 1990, that had the ball bearings in the vacuum pump eccentric go through the gear train and the pump gear was cracked all to hell, radiating from the hub out.
I have also had several pump gears that were cracked on the keyway, for whatever reason.
Postby nolafishr » Tue Oct 23, 2012 3:33 pm
Sorry to hear what happened, I just fixed my dowel pin yesterday and tightened the timing case bolts also while at it
along with some blue loctite on the threads. I hope she holds up for you.
nolafishr
Postby Billy Bones » Thu Oct 25, 2012 11:33 pm
And this is why I really like this site! What are the torque specks for the cover?
Billy Bones
Postby lopez dodge » Mon Oct 29, 2012 12:06 pm
i cleaned and inspected all the gears . the cam gear is what acually grabbed ahold of the pin . the gears all looked good , cleaned all surfaces . been driving the truck , as usual and the only thing i notice is that my lower rad hose is leaking alittle from when i put the radiator back in.
lopez dodge
