JQmile wrote: Any info on the HTT 60mm wheel upgrade? Thinking of doing a wheel upgrade and 2nd gen intercooler swap as budget mods.
thanks
Jason
nothing but good things to say about the 60mm upgrade. that is a great place to start.
thanks
Jason
Philip wrote:Get some base lines with the stock intercooler before you try that second gen swap. But before you try the second gen. Change the inlet/outlets from 2.5" to 3" on the stock IC. See if that helps first.
Some of use would like to know if that would be an improvement that is a little more cost effective and less work than the swap.
If you don't I will. But it would be summer before I get to try.
c12h26 wrote:JQmile you should put a water to air intercooler like i put on my D250.I went from a 15.03@88mph to a 14.49@90mph,it dropped the charge air temp from 589* to 120* on a run and it only cost about 200 dollars for the intercooler and couplers
