Diesel Power Magazine 1st gen buildup
Postby swank » Sun Dec 09, 2007 3:38 pm
JQmile wrote: Any info on the HTT 60mm wheel upgrade? Thinking of doing a wheel upgrade and 2nd gen intercooler swap as budget mods.
thanks
Jason
nothing but good things to say about the 60mm upgrade. that is a great place to start.
truck
swank
Postby ford69557ci » Sun Dec 09, 2007 4:35 pm
or a 64 71 s300 can be had for low dllar at a heavy duty engine core yard
ford69557ci
Postby wannadiesel » Sun Dec 09, 2007 4:53 pm
JQ, your stock injectors are big enough for 300-320 HP with pump tuning if you have the air to support it. I'd throw more air at it before you do injectors. As was said, the 7.3 liter PSD intercooler is a better fit and has more surface area than a 2nd gen Dodge unit. Upgrade the fuel supply as well, and unplug the KSB on your dyno runs/drag passes.
Best dyno: 408/844
wannadiesel
diesel guru
Postby rbrettctd » Sun Dec 09, 2007 5:49 pm
Philip wrote:Get some base lines with the stock intercooler before you try that second gen swap. But before you try the second gen. Change the inlet/outlets from 2.5" to 3" on the stock IC. See if that helps first.
Some of use would like to know if that would be an improvement that is a little more cost effective and less work than the swap.
If you don't I will. But it would be summer before I get to try.
Hes not intercooled yet...90.
Randy
rbrettctd
Postby flashgordon » Sun Dec 09, 2007 5:59 pm
I would go with the stage IV over the stage III compressor up grade.
Stage IV upgrade comes with the compressor housing that you would need for the intercooler project.
The HX35, as ford has mentioned, will give you the same compressor housing, that you need...............and may be the less expensive way to go..........But when the power starts climbing, you going to need to up date the HX35 to at least a stage III or possible a stage IV any ways.
I say, use the turbo that came with the truck and up grade it.
That being said, i when with a HX35 off of a 95 2nt gen for my 2nt gen intercooler project!.......as i have no intention of going fast enough to be classified as wild!!!!!(SAYS THE MAN AS HE STEPS OFF THAT SLIPPERY SLOPE :shock: :lol: )
When your searching the Wrecking Yards for parts make sure you pick up this part for the turbo.
http://i125.photobucket.com/albums/p58/ ... C01913.jpg
That Elbow will be required for you intercooler project, and is what Philip
was taking about with the 2 1/2 and 3"Designs.
2nt gen intercooler install.
http://i125.photobucket.com/albums/p58/ ... C01702.jpg
The stock 2nt gen tubes work on the passanger side but the divers side is another story :roll:
How ever Tim (TWorline) On this sight, is helping me with this project.
and is making me one of his big "CoolerTubz."
this is only the beginning............when it's finished it will shine better then them dirty chrome valve covers. :lol: if you look in the previous pic, you can also see it.
http://i125.photobucket.com/albums/p58/ ... C01706.jpg
To learn more about his "CoolerTubz" go down to Member Endeavors, and Click on 3" Stainless Steel Intercooler Tubes For Sale.
flashgordon
Postby cummins king » Sun Dec 09, 2007 6:49 pm
just for get the whole ic idea and just put on killer water meth kit in you can get them cheap at devils own im probaly going to remove my ic and od that, oh if you get a polish and porting job done you wont need a ic or water meth of around 350hp or less
93 4X4 auto
cummins king
Postby ford69557ci » Sun Dec 09, 2007 6:57 pm
im probably above 350 hp and i am still non ic'ed and i just hose it with some water its the fun way to do things.
ford69557ci
Postby cummins king » Sun Dec 09, 2007 9:01 pm
ya and it alot cheaper i belive the guys that are running dragsters they have no ic and they spray lots of water
93 4X4 auto
cummins king
Postby flashgordon » Sun Dec 09, 2007 10:06 pm
Yes, but the intercooler is maintenance free............and the lower the egts, the more fuel you can pour on it.
W/M system it grate..........But with a intercooler it would be even better......and if it's not......you need more fuel :mrgreen:
flash
flashgordon
Postby ford69557ci » Mon Dec 10, 2007 12:24 am
if schieds pull trucks dont need one niether do i and i think there is a 9sec 4x4 dodge in dp mag that has no cac
ford69557ci
Postby Cschafer » Mon Dec 10, 2007 12:50 pm
Mine with stock 50mm turbo w/14non gated housing, tuned pump, banks intercooler, straight pipe and stock everything else made 301 on a dyno jet, the s300 and intake(bhaf) made 319HP. Thats all with stock injectors. Don't bother with 60mm wheel if your going for 500, Bigger injectors and s300 will put you over 400 and with a little bottle your already above your goal. Now I don't think anybody has tried a 450+ combo with an h1c or hx35, could be cool. Get some 5x16's or 18's, externally gate the turbo and spray the crap out of it. I think the real problem with getting horsepower is #2 only. If your not afraid of NOS (just kidding, nitrous) You should be able to make that thing rip.
91 w250 wrecker
Cschafer
Postby c12h26 » Mon Dec 10, 2007 1:29 pm
JQmile you should put a water to air intercooler like i put on my D250.I went from a 15.03@88mph to a 14.49@90mph,it dropped the charge air temp from 589* to 120* on a run and it only cost about 200 dollars for the intercooler and couplers 8)
1991 D250 reg. cab 518
4" turbo back,pump turned up,bumped timing,intercooler,HX52,366 spring,ground AFC lever,piston lift pump,Goerend converter,M/T ET street radials,nitrous,lowered.
c12h26
Postby JQmile » Mon Dec 10, 2007 2:04 pm
Thanks for all the advice guys....I do have the stock turbo and intercooler leftover from my '97 dually that I could adapt.......that might be cheap and fix both my problems...although I do like the idear of an air to water intercooler, thanks for bringing it up! Not afraid of nitrous, have three stages worth sitting in a box, just concerned about how much $$ I can spend before I get out of the "budget" range. Already have injectors, so I have plenty of fuel, but right now I am out of air.....
JQmile
Postby 2stroke » Mon Dec 10, 2007 2:29 pm
c12h26 wrote:JQmile you should put a water to air intercooler like i put on my D250.I went from a 15.03@88mph to a 14.49@90mph,it dropped the charge air temp from 589* to 120* on a run and it only cost about 200 dollars for the intercooler and couplers 8)
have any more info on this?
91 non I/C w-350 SRW
2stroke
Postby ford69557ci » Mon Dec 10, 2007 4:39 pm
the second gen stuff you have layin around would work just great for a budget build especially if you are goin to bottle it.
ford69557ci
