Turbo lights early
Turbo lights early
Postby cummins32 » Thu Nov 29, 2012 9:10 pm
I installed some diesel auto power 5x12's and I really like em, but my turbo lights at about 9 pounds, if I get on it the truck starts screamin at 9 pounds of boost, It's a little too early for me, I was thinkin an hx40, my friend has one that I can get for pretty cheap, but it needs a new compressor wheel, so I was thinkin a batmowheel ?
Diamond eye 4 inch turbo back, Glowshift boost, egt, oil pressure,hx35 , 3200 rpm spring, full power screw 2 turns, denny T II fuel pin, Home made Cold air intake, Alto reds and tci TC in a 518, 5x12's from diesel auto power.
cummins32
Re: Turbo lights early
Postby cummins32 » Thu Nov 29, 2012 9:16 pm
It basically spols to fast for me
cummins32
Postby Tacoclaw » Thu Nov 29, 2012 9:28 pm
How dare it.
Seriously though, what is the problem here? If it's too hard to drive easy then try tightening your starwheel up. If that's not enough try your stock fuel pin again.
Postby cummins32 » Thu Nov 29, 2012 9:30 pm
Ok, I'll try that, Thanks
cummins32
Postby Tacoclaw » Thu Nov 29, 2012 9:51 pm
And to clarify, by tightening your starwheel I technically mean to loosen it up, thus increasing tension on your AFC spring.
Postby PToombs » Fri Nov 30, 2012 5:44 pm
What he means is turn it up towards the top. ;)
I have a friend with a powerjoke, (i know, i know, he's more of an aquiantence actually ;) ) He read that a Batmowheel actually makes less power, somebody did a comparison test. I'm not sure if that was compared to a stock wheel or a performance wheel the same size, I'm not up on all that ferd crap.
Postby dazedandconfused » Fri Nov 30, 2012 5:54 pm
PToombs wrote:What he means is turn it up towards the top. ;)
Borgwarner was testing them because people were not buying replacement Borgwarner parts because all the hype of the batmowheel bs.
Postby Tacoclaw » Fri Nov 30, 2012 9:49 pm
From what I saw there the Batmo gives a little fatter bottom end to the charger but really gives up capability up top. Honestly besides the price I don't see a downside to that in a street truck, but it's definitely not worth the $$ for the little extra air it gives you.
Postby Deathrod » Sat Dec 01, 2012 10:26 am
Hey hey, let's be easy, I drive a powerSTROKE!!!!!, let the bashing begin :D :D :D Talk all the crap you'd like but the actual truck part is much better then anything dodge ever made!!!
Deathrod
Postby tampabayBill » Sat Dec 01, 2012 7:38 pm
We all have our problems.
Twins coming soon!
tampabayBill
Postby revemup15 » Sat Dec 01, 2012 7:52 pm
Amen
94 p-pump
revemup15
Banned
Postby Mark Nixon » Sun Dec 02, 2012 8:36 am
Bitch and whine all you want, in the end it takes a DODGE IDEA to keep a POS FORD running.
Postby bmoeller » Sun Dec 02, 2012 9:02 am
Whining because the turbo lights fast? Really.......... Most piss and moan about the lag.............. Don't want it to light off as fast, don't stand on the go pedal. :p Problem solved! :lol:
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby cummins32 » Sun Dec 02, 2012 5:01 pm
Like that will happen lol, lead foot
cummins32
Postby bmoeller » Sun Dec 02, 2012 5:16 pm
Then stop b*tchin'! :lol:
bmoeller
