am i f'ed
am i f'ed
Postby skilletky » Fri Dec 21, 2012 5:41 pm
i got the W/M to work. i put the pump and res. in the bed. was out today getting lunch, got back to work and parked the truck. i parked it on a small incline, front of the truck down. well, as it sat there while i was working, some of the boost juice gravity fed into the engine. i went to start it and it didnt want even turn over. at first i thought the starter was not working, but the 3rd attempt made it clear what was going on. i got pretty mad figuring i bent a rod, so i said screw it and tried a 4th time. it started but ran like crap for a minute. but it cleared up and runs a good as ever now. i checked the oil and i could tell there is a little something other than oil in it. i dont think its coolant. i think it is boost juice that had leaked into a cyl or 2. i checked coolant and it is fine. i was just going to change the oil and hope for the best. any of yall thing i blew my head gasket, or did any other damage? sorry for the novel. lol
skilletky
Re: am i f'ed
Postby turboram » Fri Dec 21, 2012 5:59 pm
Change oil drive on. Then go buy a check valve. My employe put on a kit that had no check valve and mounted the tank higher than the nozzle and started it 2 different times till it got figured out and still has no problems since then
turboram
Re: am i f'ed
Postby PToombs » Fri Dec 21, 2012 6:02 pm
Sounds to me you got lucky and didn't hurt it. X2 on the oil change and a check valve. ;)
Re: am i f'ed
Postby skilletky » Fri Dec 21, 2012 6:20 pm
Defiantly changing the oil Tom. Maybe even twice. I got a 7 gallon tank and solenoid on the way.
skilletky
Re: am i f'ed
Postby skilletky » Sat Dec 22, 2012 9:44 am
i guess we will all live to see another day, and so will the ol cummins. changed the oil, let it run for about 10 min, drained it, filled it up again and put on a new filter, put some new fuel filters on, and gave her hell. no problems yet, nothing but oil in the crank case. i drained the boost juice out of the W/M tank and blew the lines out until the new res. shows up with the solenoid.
skilletky
Re: am i f'ed
Postby BC847 » Sat Dec 22, 2012 10:02 am
Sooooo, . . . . . is the W/M worth anything?
Re: am i f'ed
Postby skilletky » Sat Dec 22, 2012 10:46 am
I can tell a very very noticeable difference all the way through the rpm's.
skilletky
Re: am i f'ed
Postby skilletky » Thu Dec 27, 2012 2:11 pm
got everything hooked up and it finally works with no problems!! i just need to find a box to put it all in to keep it out of the elements and away from dumb people, but this will do for now.
skilletky
Re: am i f'ed
Postby 12vsuburban » Sun Dec 30, 2012 2:28 am
which system did you buy?
12vsuburban
Re: am i f'ed
Postby skilletky » Sun Dec 30, 2012 7:01 am
Snow performance stg 3. They call it the tow max now.
skilletky
