installing a tach in a truck without the crank pickup
Postby dodgeman1990.5 » Sun Oct 21, 2012 6:25 pm
i am looking to install a tach in my truck but it dosnt have the pickup on the crank. i havent found much online about it
dodgeman1990.5
Re: installing a tach in a truck without the crank pickup
Postby BILTIT » Sun Oct 21, 2012 6:31 pm
isspro makes them.
Derek B.
BILTIT
Postby Hansen01 » Sun Oct 21, 2012 6:32 pm
They make one with a pickup that gets clamped around the alternator, i have one and it works great
Under construction...
Hansen01
Postby dodgeman1990.5 » Sun Oct 21, 2012 6:37 pm
Hansen01 wrote:They make one with a pickup that gets clamped around the alternator, i have one and it works great
i was just reading about the alt pickup ones, i guess once you set them up you need a hand held diesel tach meter to calibrate it.
dodgeman1990.5
Postby BILTIT » Sun Oct 21, 2012 6:40 pm
The one i have from isspro uses two magnets glued to the balancer and a sensor.
Derek B.
BILTIT
Postby Hansen01 » Sun Oct 21, 2012 6:45 pm
Yup
Mine is an autometer
Hansen01
Postby dodgeman1990.5 » Sun Oct 21, 2012 6:49 pm
BILTIT wrote:The one i have from isspro uses two magnets glued to the balancer and a sensor.
thanks that is the kind i am looking for do you have the part number by any chance?
dodgeman1990.5
Postby BILTIT » Sun Oct 21, 2012 9:34 pm
http://www.genosgarage.com/ISSPRO-R5503 ... ISS-R5503/
See the note at the bottom of that page.
Derek B.
BILTIT
Postby dodgeman1990.5 » Sun Oct 21, 2012 10:08 pm
thanks
90 w250 flatbed was daily driver now a restoration project
91 d250 non intercooled, fuel screw, ground fuel cone, intercooled turbo,
dodgeman1990.5
Postby 12vsuburban » Sun Dec 30, 2012 3:17 am
I have the Autometer one that straps the sensor to the alternator on my Toyota turbo deisel powered '57 Landrover....works great...
12vsuburban
Postby rockmike » Wed Jan 23, 2013 10:41 am
I also run the Autometer unit,I had issues with that needle bouncing bad!Took some trial and error to find the sweet spot on the alt,then the needle hold steady!
I parked mine next to a buddys that has the crank trigger and we just tweaked the idle screw till it sounded just like his truck to our ears and feel then calibrated the tach to 800rpm@ idle,called that good to go 8)
rockmike
