wetness around manifold
Re: wetness around manifold
Postby 1992gen1_fan » Sat Dec 29, 2012 5:34 pm
My truck smoked like crazy all the time when it had that problem. At its worst point the mpg dropped to less than 7 mpg too. Yours don't sound like as bad of a problem.
If you're sure theres nothing wrong with the oil or coolant and you're sure the head gasket or valve cover gaskets aren't leaking on the manifold, bring the injectors to a diesel shop. It would'nt hurt to get the injectors "popped". One might be randomly sticking.
1992gen1_fan
Postby 1990CTD » Sat Dec 29, 2012 8:23 pm
My truck just white smoke a bit when cold. It don't leak any at valve covers or the head gasket, it actually don't leak anywhere at all!! It also run like a champ, I actually turned it sideways in the road today when I goosed it, and if I just goose it driving around it breaks 285s over really easy!! So I may have em popped, but I'm really not worried about it. I only see it when it first starts when I look under hood. When you rev it , that's when you see it. Bit when warm I don't see it but it probably evaporated. What will oil look like if it has fuel in it?
1990CTD
Postby 12vsuburban » Sun Dec 30, 2012 2:11 am
post a pic of where you are talking about...form the post its not even really clear if your talking exhaust manifold or intake manifold...
12vsuburban
Postby 1990CTD » Sun Dec 30, 2012 7:11 am
Sorry, I couldn't figure out how to post them. But its the exhasut manifold where the gasket is. Its coming from the gasket on the exhaust. When you rev it up cold, you can see a little liquid coming from it. It bubbles out dirty yellow when you rev it.
1990CTD
Postby dazedandconfused » Sun Dec 30, 2012 8:03 am
Link in my sig tells how to post pics.
Postby Hansen01 » Sun Dec 30, 2012 1:08 pm
I noticed mine had some oil or something coming out the manifold a little bit as well, head and injectors were done a year ago. but then again it might not have done it before it tryed to roll over like a dog..
Under construction...
Hansen01
Postby 1992gen1_fan » Sun Dec 30, 2012 10:10 pm
1990CTD wrote:My truck just white smoke a bit when cold. It don't leak any at valve covers or the head gasket, it actually don't leak anywhere at all!! It also run like a champ, I actually turned it sideways in the road today when I goosed it, and if I just goose it driving around it breaks 285s over really easy!! So I may have em popped, but I'm really not worried about it. I only see it when it first starts when I look under hood. When you rev it , that's when you see it. Bit when warm I don't see it but it probably evaporated. What will oil look like if it has fuel in it?
Fuel in the oil will make the oil feel thin and make it smell like diesel, it might not make it look any different.
If everything checks out and the truck runs good, maybe when the manifold cools it gets condensation and leaky gaskets let it leak out when you start the engine :? Thats all I can think of.
1992gen1_fan
Postby 1990CTD » Mon Dec 31, 2012 9:19 am
I still can't post them. If someone wants to send me their number I can send you a pic. But ill smell and feel the oil. I hope its just the condensation thing.
1990CTD
Postby 1992gen1_fan » Mon Dec 31, 2012 6:22 pm
I upload to my photobucket account and copy the IMG code to the post
1992gen1_fan
Postby 1990CTD » Mon Dec 31, 2012 8:00 pm
Ill try to put some up. Ill have to get pics tomm.
1990CTD
