injector swap
injector swap
Postby dunes450r » Tue Jan 08, 2013 8:39 pm
so i just sent my cores in on a set of injectors from DAP. i already have a reseal kit like this one: http://www.cumminsperformanceparts.com/ininsekit.html
but mine also has some rubber things that look like you put them over the injectors themselves?
my main question is: the kit has 3 different thicknesses of sealing washers and i'm unsure which ones to use?
any help is appreciated
dunes450r
Re: injector swap
Postby AHineman » Tue Jan 08, 2013 8:51 pm
I'd run the thinnest set to help with haze.
Re: injector swap
Postby RCCUMMINS89 » Tue Jan 08, 2013 9:37 pm
Yep, run the thinnest.
Re: injector swap
Postby PToombs » Wed Jan 09, 2013 6:31 pm
The o-rings, are they cut square? If so, they seal the injector body to the nut tp keep the crap out. I slide them on, then I use a small pick to push them into the gap.
