turbo ??
turbo ??
Postby D-dog357 » Mon Jan 07, 2013 9:45 pm
My ol' truck - 92 250 ex-cab w/slush - has the 21cm pig on it and I have a complete 18cm non-ic to swap in. I will be towing a 5-6k trailer cross country soon and want to keep it cool on the hills.
By the time I head out the pump will be set at - Smoke in 3/4, star down 1, fuel to the collar and a 366. Should I just go ahead and do the swap or wait till I can afford a 16cm housing and make the run the way it is?
Thanks for any advice you might have.
D-dog357
Re: turbo ??
Postby Horus » Mon Jan 07, 2013 10:34 pm
KOH by chance?
91.5 W250 Dodge 4X4 CTD. Getrag. DD Power pin removed, stock fuel cone back in. 366 spring. Power screw at stock depth. Stock turbo. Stock lift pump. Straight piped and Intercooled.
93 D250 Dodge club cab 2wd. All stock for now. Automatic.
Hard KOR Wheeler.
PNWJeep club member.
Horus
Re: turbo ??
Postby PToombs » Tue Jan 08, 2013 6:14 pm
Either a 12cm or a 16 is way better than what you have. An 18 is not worth changing to, not small enough to make a difference.
Re: turbo ??
Postby D-dog357 » Tue Jan 08, 2013 8:40 pm
Thanks Toombs, That's what I thought but it never hurts to ask - at least not too much.
D-dog357
Re: turbo ??
Postby Remps » Wed Jan 09, 2013 10:12 am
Your 21 cm turbo has a 54 mm compressor, the non intercooled turbo has a 50 mm compressor. Thats why i mentioned a turbine housing swap.
Re: turbo ??
Postby D-dog357 » Wed Jan 09, 2013 10:36 pm
Remps, Thanks for taking the time to explain. I was considering doing a total swap as was recommended on another site.
Nice to get detailed info in a reply - thanks again.
D-dog357
