piston lift pump came apart
Postby dunes450r » Thu Jan 10, 2013 2:49 pm
so i'm just getting around to rounding up parts to install a hvlp lift pump that i got used from a member on here. figured i'd open the pump up real quick before installing it just to make sure everything is good to go inside. and here is what i found:
i'm sure the seller had no idea it was like this since he had ran it with no issues before pulling it off in favor of something else. i've sent him a message to discuss options but i'm curious what everyone's opinion is on what can be done with pump. is it salvageable? what should i do?
what kind of lift pump screen or prefilter are ya guys running to keep junk out of your piston lp?
http://www.westmarine.com/webapp/wcs/st ... O83V3d4KTA
is this too simple?
dunes450r
Re: lift pump screen/prefilter
Postby cmann250 » Thu Jan 10, 2013 2:57 pm
Yea that'd work. I'd bet you could find one even cheaper at the local lawn mower shop.
I've seen guys use this too http://www.genosgarage.com/FLEETGUARD-U ... fo/FF5079/
Re: piston lift pump came apart
Postby dunes450r » Wed Jan 16, 2013 5:40 pm
anyone? appears the parts that got chewed up are the diaphragm/one way valve that lets fuel travel from the inlet side to the pressure side of the piston?
dunes450r
Postby revemup15 » Wed Jan 16, 2013 7:50 pm
Just buy a lpplp kit from rccummins
94 p-pump
revemup15
Banned
Postby RCCUMMINS89 » Thu Jan 17, 2013 10:23 am
Over on Cummins Forum, there is currently a used low pressure piston lift pump kit for sale for $150.00
It's not one of my kits, so I don't know if it's a DAP kit or a Cummins lift pump. If that's a Cummins pump, that's a steal.
Postby ellis93 » Thu Jan 17, 2013 10:52 am
RCCUMMINS89 wrote:Over on Cummins Forum, there is currently a used low pressure piston lift pump kit for sale for $150.00
Is there issues w/ the dap pumps?
Postby RCCUMMINS89 » Thu Jan 17, 2013 10:56 am
An issue? No, but they are not a whole lot better than a stock diaphragm style. They seem to push anywhere from 5-9 psi (sometimes a bit more), and aren't near the quality or move the fuel that the Cummins low pressure pump does.
There is a reason that you can buy the DAP pump, directly from Oregon Fuel Injection for $78.00
Postby ellis93 » Thu Jan 17, 2013 10:59 am
RCCUMMINS89 wrote:An issue? No, but they are not a whole lot better than a stock diaphragm style. They seem to push anywhere from 5-9 psi (sometimes a bit more), and aren't near the quality or move the fuel that the Cummins low pressure pump does.
Didn't know that.
Postby dunes450r » Fri Jan 18, 2013 9:49 am
i just need the member that sold me this pump to get back to me now......
dunes450r
Postby rockmike » Wed Jan 23, 2013 10:04 am
I have that lil valve screen doohicky in an old #@*^#* piston LP im replacing.
Pm me you address and I'll mail it to ya if you would like?
rockmike
Postby dunes450r » Wed Jan 23, 2013 3:31 pm
rockmike wrote:I have that lil valve screen doohicky in an old #@*^#* piston LP im replacing.
thanks
dunes450r
Postby CumminsPower59 » Wed Jan 23, 2013 3:49 pm
That inlet screen catches only the really big stuff, what I have used before is a in line strainer, Fleetguard FF5079. It will keep out the junk that gets pulled up from the tank. Without a capable strainer, the screen can plug, and/or the piston walls will get scored, hindering output...
Postby PToombs » Wed Jan 23, 2013 5:44 pm
CumminsPower59 wrote: the screen can plug, and/or the piston walls will get scored, hindering output...
BTDT. :(
Postby dunes450r » Wed Jan 23, 2013 10:10 pm
CumminsPower59 wrote:That inlet screen catches only the really big stuff, what I have used before is a in line strainer, Fleetguard FF5079. It will keep out the junk that gets pulled up from the tank. Without a capable strainer, the screen can plug, and/or the piston walls will get scored, hindering output...
i wish that was the problem, the diaphragm is trashed, as in it came apart and the previous owner kept running it without knowing, then sold it to me....
dunes450r
Postby cmann250 » Thu Jan 24, 2013 5:57 am
Just a related question, how often should one change that pre filter?
