I got the HE351ve installed
Postby 91bluecummins » Mon Jan 21, 2013 6:29 pm
this turbos awfull big
after 5 hrs of sanding and polishing
Custom adapter
custom 4inch downpipe its a tight fit but no rubbing
all together, then i ran PTO cable inside of the cab to control it
92 cummins W250 extenged cab (The Goat) project truck
90 cummins W350 single cab dually flat bed 5 speed, he351ve 62mm
1959 chevy Apache 4bt cummins 4 speed
91bluecummins
Re: I got the HE351ve installed
Postby Deathrod » Mon Jan 21, 2013 9:48 pm
Looks good, I keep mine about 2/3s open as default and close it up I bit under acceration, seems to net me best mpg/ egts
How does it compare to the last turbo?
Deathrod
Postby Diesel Dawg » Tue Jan 22, 2013 2:03 pm
What did you need the adapter for I thought the He 351ve had a T-3 foot also.
Diesel Dawg
Postby DodgeFreak » Tue Jan 22, 2013 3:10 pm
ve's have a different flange from a t3 or t4 or the t4i. from what i've researched its a wgmt flange or something.
edit: the 351cw have the t3
Postby 91bluecummins » Tue Jan 29, 2013 10:31 am
This one came off a 2008 6.7. It has the t4i flange. It spools good and make some good power and keeps the egts low with those pod injectors. The whistles loud with it closed up but u get used to it.
91bluecummins
Postby rockmike » Tue Jan 29, 2013 11:35 am
Some good info,nice sanding and polishing job 8) If im not happy with my EGT control now with W/M im going to look at this HE 351cw turbo for the true 4" exhaust.
93 d350 extra cab 5 speed dually.
Mods: hx35,rotated fuel pin,bosch 190 inj.,BHAF with smooth intake tube,3200 rpm spring,M&H dynamic timing spacer,isspro EGT and boost gauge,Auto meter tach, fuel press. gauge.Diamond eye 4" exhaust,Sno Stage 2 W/M kit.
Real trucks dont use spark plugs!
rockmike
Postby dieselcountry85 » Thu Jan 31, 2013 8:40 pm
Did you have to flip the exhaust manifold?
dieselcountry85
Postby 91bluecummins » Fri Feb 15, 2013 6:28 pm
No I didn't haft to flip the manifold it fit snug though but it all clears even with the 2.5 inch eletric controller I had on it at first
91bluecummins
