BILTIT wrote:As stated, YOU NEED IT!!
m880cummins wrote:Before you buy it, remove the high speed screw. It looks just like the idle adjustment screw but it limits how much you can pull the throttle back. Pull that screw out and take the slop out of your go pedal. That will yield another 2-400 rpms.
Doing the 3200 spring is cheap and not entirely hard. A reseal kit is a good idea if you are diving into the pump.
Charlie
