just bought my first 1st gen 1992 w250
Postby benbo30 » Thu Mar 28, 2013 10:34 am
ok so a couple questions , I just bought my first 1st gen , w250 automatic with a dually conversion and flatbed .... well recently i.just found out that my head gasket is leaking in front corner under thermo. housing , so I've called a few shops to do the head gasket , well here is what im thinking since its.already gonna be at the shop I was looking into doing injectors , killer dowl pin , fuel pin and gov. spring.
injectors wise Im thinking ddp stage 2 75hp , will the stock turbo handle them or ?
I am planning on doing a turbo in future .
this is will be daily driver / tow rig
benbo30
Re: just bought my first 1st gen 1992 w250
Postby dazedandconfused » Thu Mar 28, 2013 10:43 am
Welcome to the site. Honestly if it were me I would just have the headgasket fixed and save for a built transmission. Being an auto it won't take much more then stock HP.
Postby RCCUMMINS89 » Thu Mar 28, 2013 10:44 am
IMO DDPs aren't worth the money.
Your stock injectors will be able to support all the fuel your stock turbo can handle... if you turn the pump up.
What's your overall goals with the truck? I'd mess with the "free mods" and see if you want more power before spending that much on inj/turbo.
Postby benbo30 » Thu Mar 28, 2013 10:53 am
also gauges are.on the way , has straight exhaust but will be upgrading to 4 inch I think the one on truck is.stock pieced together to get rid of.muffler.
basically im just wanting to make a good tow rig , but would like some power too ...as far as transmission goes plan is to find a donor w250 & 5 speed swap it
benbo30
Postby benbo30 » Thu Mar 28, 2013 11:09 am
RCCUMMINS89 wrote:IMO DDPs aren't worth the money.
basically im just wanting to make a good tow rig , would like some power too ...as far as transmission goes plan is to find a donor w250 & 5 speed swap it
benbo30
Postby cmann250 » Thu Mar 28, 2013 11:10 am
Welcome.
Postby CumminsPower59 » Thu Mar 28, 2013 11:12 am
Welcome! Post up some pics!
Postby benbo30 » Thu Mar 28, 2013 11:14 am
pics will come when I get home to my computer
benbo30
Postby benbo30 » Thu Mar 28, 2013 7:49 pm
here is the truck ... one clean 1st gen
benbo30
Postby dazedandconfused » Fri Mar 29, 2013 2:14 am
Now that is one sexy truck.
Postby bmoeller » Sat Mar 30, 2013 7:03 pm
Not a fan of the rims, but it's a purdy truck! :D
SOLD- '99 3500, SO CTD, 5spd
bmoeller
Postby RCCUMMINS89 » Sat Mar 30, 2013 7:17 pm
I likes it.
Postby Diesel Dawg » Sun Mar 31, 2013 10:04 pm
Do studs and maybe O-ring the head, Cummins HG and install gauges. Then turn up the fuel and see how it goes.
Diesel Dawg
Postby peobryant » Tue Apr 02, 2013 2:29 am
benbo30 wrote:here is the truck ... one clean 1st gen
Great looking truck.
