BC847 wrote:My mess with 6x.016" injectors will pull 15psi down to a little over 12psi at full song. Frankly, the more I screw with this case-pressure thing, the more I wonder if there's really an advantage to more than 15psi.
TRACTJDS0428 wrote:BC847 wrote:My mess with 6x.016" injectors will pull 15psi down to a little over 12psi at full song. Frankly, the more I screw with this case-pressure thing, the more I wonder if there's really an advantage to more than 15psi.
will a high volume low pressure piston lift pump hold flow and pressure as the rpms increase or do i need to look more at a pressure regulated return fuel system?
BC847 wrote:TRACTJDS0428 wrote:BC847 wrote:My mess with 6x.016" injectors will pull 15psi down to a little over 12psi at full song. Frankly, the more I screw with this case-pressure thing, the more I wonder if there's really an advantage to more than 15psi.
Will it supply 6x.016" injectors? Absolutely not.
What size injectors do you plan on running when all is said and done? That will determine what fuel supply you need.
It's not a thing of pressure so much as it is volume. If you can't keep up with the demand of volume, the pressure will drop.
