what in the world is this growling I hear in my 92
Re: what in the world is this growling I hear in my 92
Postby PToombs » Sun May 05, 2013 4:07 pm
That's cool! I saw a chevy 350 with a broken crank once, it ran too, made a nasty knocking noise though. 8) After that when my boss ran to Pennsylvania for fish food, a 4-500 mile run, he made sure to ask if the truck would make it there and back, instead of just asking if it would make it there like he did the day the crank broke. :lol:
Postby dazedandconfused » Sun May 05, 2013 4:26 pm
I've seen plenty 6.5s do that but never a stockfish Cummins.
Postby hager » Sun May 05, 2013 6:19 pm
yeah I'll post some more pictures when I pull the crankshaft out let you guys know what's going on .I'm afraid to put this thing on my engine stand it's pretty heavy anybody know how much a block weighs no head
hager
Postby Rob_O » Sun May 05, 2013 6:54 pm
hager wrote:Image
Yeah, that'll make her rattle a little...
Rob_O
Postby dazedandconfused » Mon May 06, 2013 3:30 am
Mount the block side ways. Attach were the motor mount plate bolts.
Postby PToombs » Mon May 06, 2013 5:10 pm
Complete engine with head, fuel pump, turbo, etc., is 1100 lbs. So I'd guess without the head, turbo, etc, still in the 850 range.
Postby hager » Mon May 06, 2013 5:24 pm
thank you men. I like what you said about bolting it sideways I think I'll try that my engine stand rated for 1300 pounds so I should be in good shape I'm out here right now working on it getting it all a strip down
hager
Postby PToombs » Tue May 07, 2013 5:56 pm
That's the way the OTC shop stands are, mounts them on the side of the block. We have 3 or 4 different engine adapters and they all mount on the side.
Postby Mark Nixon » Thu May 09, 2013 4:31 pm
Never saw a Cummins crank broken like that and I have pulled a BUNCH apart. :shock:
I've pulled ones apart that were so oil starved that the main caps and crank were black and blue scorched, a couple that had CHUNKS missing from the block main saddles, but to this very day I have NEVER pulled a Cummins crank that was broken anywhere similar to that, abused or not.
What was your oil pressure like with it broken that way? :?
It should have been noticeably low or erratic.
Postby hager » Thu May 09, 2013 4:39 pm
yeah I've never seen anything like it myself this is my first time this far in an engine
no pressure was low and sporadic not even really alarming low just slightly low but I've had sending units go out on these before they are pretty fickle so I didn't think much of it . and i didn't have a whole lot of time to react to the low oil more the sound I'm having magnaflux Monday and lineboard hopefully soon after . up here in North Missouri there not a whole lot of machine shops
send this is my first time pulling an engine and working on it any suggestions would be much appreciated.
hager
Postby hager » Tue May 14, 2013 3:33 pm
a little update I found a crankshaft out of an engine that has a hundred sixty thousand miles on it it looks good I give $150 for it I found all new connecting rods 100 bucks used and and I've yet to get the block Iooked at or Magnafluxs planning on doing that the next day or so I'll post more pictures I did get the crankshaft out and it is in 2pieces pretty much a mess
hager
Postby dunes450r » Tue May 14, 2013 4:57 pm
i'm sure you already know but, need to clean everything really good. who know how much metal chips made it everywhere.
dunes450r
Postby hager » Thu May 16, 2013 3:23 pm
Yeah right now it's at Napa in town getting boiled clean thanks friend
hager
Postby hager » Tue May 21, 2013 8:02 pm
Imagehere's an update picture
hager
Postby hager » Tue May 21, 2013 8:07 pm
hager
