cmann250 wrote:I was thoroughly impressed when I took the test run around the block the first time with my piston pump. I had a brand new stock LP previously to boot.
cougar wrote:cmann250 wrote:I was thoroughly impressed when I took the test run around the block the first time with my piston pump. I had a brand new stock LP previously to boot.
I've only noticed a slightly better throttle response, nothing note worthy.
cougar wrote:After sitting on the shelf for a year, finally got round to installing the low pressure piston lift pump. What a pain, took about 3 hours to do. Guess that's what happens when you get fat and old. Had to take the hood off, throttle cable bracket, and moved the dip stick tube and wiring harness out of the way. I was about ready to remove the master cylinder. All this just to cut away the insulation on the valve lifter cover. Scraping away the old gasket was a lot of fun too. Bought the Delphi pump, we'll see how long it hold up. If I have to replace it and/or do the 92 I'll use a high volume with a low pressure spring. There are some out there now.
