by nyford » Thu Aug 15, 2013 1:45 pm
So the truck ran great. Pretty good mileage. My egt's were down compared to the stock setup before, (1200 vrs 1100) that has me baffled, I would guess that I have less timing than I did before.
The only issue I had is that on one of the hills on the way home I got a "chugging" problem under wot up the hill. I had the problem once before and I think it is electrical. A problem with the connection to the fuel shut off.
Getting back to the egt issue, the boost seemed to be down some too. It felt like the truck would hit a wall at about 2200 in 4th. If I shifted into 5th, she would pull again fine. Before it seemed that she would pull all the way to 2500. I am wondering if I am either running out of turbo or she needs more fuel.
Fummins project. 89 f350 w 95 front end, 4x4 dually crew cab, 89 6bt, pump tweeked, studded, marine 370's, intercooled, 4" turbo back, 12 cm housing, nv 4500. divorced 205, 4.11's, 265/70/19.5's
