Postby CumminsPower59 » Wed Jul 03, 2013 9:45 pm
I got a tach, wouldn't work right, kept adjusting the magnetic pickup until I said fack it and pulled it back a ways...works perfect :roll: I have contemplated removing the lift and go to 285's or the like....but it looks so good with the mild lift :mrgreen: I don't use 5th under moderate to hard acceleration, just when its going down the road 55-60. The thing has a miss at 1700 rpms and gets worse as the rpms go up....so I don't wind it up unless its absolutely necessary....
Postby CumminsPower59 » Tue Jul 09, 2013 10:53 am
Update. I put almost 400 miles on The Pile, been using GPS as the speedo/odo is slightly off. Filled it up again and it got 20.9 mpg :mrgreen: Not too shabby for the turd, running like it does. After I get back from my two week Army vacation in WY :roll: the plan is to get the new pump on, run an overhead, get the sticks cleaned and popped, install the clutch, new steering shaft, re-build the rear suspension and get the Kelderman on, finish the interior, paint the inside of the bed, and fix the brakes...again. Planning on running it as much as I can when it's done...
Postby cmann250 » Wed Jul 10, 2013 3:37 am
Did that rear harness show up yet?
Postby CumminsPower59 » Wed Jul 10, 2013 8:40 am
Sure did! Thanks!
Postby cmann250 » Wed Jul 10, 2013 10:49 am
Good. I don't trust the Post Office :lol:
Postby CumminsPower59 » Wed Jul 10, 2013 12:51 pm
I also don't trust the postal system, since my recent injector pump shipping debacle...it finally showed up...
Postby CumminsPower59 » Thu Aug 01, 2013 10:58 am
Update. Got a 184 pump and intercooled lines put on, truck runs out well...but I ran into a few small issues on install. It appears that I need to do something with the intake temp sensor, as the lines contact it. Would switching to an intercooled intake plate solve this? Or, sould I put a plug in the opening, and drill and tap the intake horn or plate for the sensor? Has anyone done something like this?
Postby cmann250 » Thu Aug 01, 2013 12:31 pm
I don't know for sure, but I'd think if you switched intake plates you'd risk having to rearrange your intercooler piping.
Postby Tacoclaw » Thu Aug 01, 2013 12:34 pm
Aren't they the same plate, the IC one is just turned around backwards?
Postby oldestof11 » Thu Aug 01, 2013 4:49 pm
Ike, i dont know why i havrnt posted in here yet...
Looking good! Keep the lift, looks great that way!
Postby CumminsPower59 » Fri Aug 02, 2013 8:33 am
Caleb, I was expecting that would happen...
Taco, I wish it was, but on the rear of the IC plate there is a boss for the air intake temp sensor...
Jon, Thanks!
Postby CumminsPower59 » Mon Sep 16, 2013 4:02 pm
Well, it's been a while, but progress is being made. Today, I FINALLY got my South Bend clutch in, thoroughly impressed. Works well and grabs like it should. For it done just in time to run to the Post Office and pick up some packages...one was from RC, my 370's have arrived! Tomorrow, I am swapping injectors and injection pumps, I got a N.O.S. 205 pump, time to put it on.
Postby Tacoclaw » Mon Sep 16, 2013 6:52 pm
CumminsPower59 wrote:Caleb, I was expecting that would happen...
Jon, Thanks!
My intake temp sensor screwed into the intake shelf, I assume all Cummins heads have this boss. If there's not an interference problem with the injector lines I don't see a problem running it like that.
Postby CumminsPower59 » Mon Sep 16, 2013 7:50 pm
Unfortunately there is some interference, one of the lines hits it pretty good, I've tweaked it a bit in an effort to clear it, but it still hits...
Postby Tacoclaw » Tue Sep 17, 2013 3:45 am
