Rubber Fuel Line Replacement
Postby Diesel » Thu Sep 26, 2013 7:19 pm
Hey guys, I think my rubber lines need to be replaced. For the first time in the many years I've had my truck I can smell a little raw diesel around the truck. Lift pump is new and not leaking and its not leaking from the fuel filter area. Pretty sure its got original rubber lines. So heres the questions: 1. the tank has to be dropped so do I replace the straps too? 2. What size rubber line are we talking about? I want to find all Made in USA hose and clamps so I'll search around.
1991.5 D250 Intercooled A518
Diesel
Re: Rubber Fuel Line Replacement
Postby RCCUMMINS89 » Thu Sep 26, 2013 7:46 pm
I wouldn't worry about straps unless they are rusted badly.
Factory comes with plastic lines. So if you have rubber they've already been replaced.
I'd run 3/8" supply and a 5/16" return.
Postby Diesel » Thu Sep 26, 2013 8:34 pm
RCCUMMINS89 wrote:I wouldn't worry about straps unless they are rusted badly.
Not exactly sure what I have - I should have specified that.
So factory is hard plastic line with soft elbows? If that's still there do I just replace the elbows with new soft line or is everyone running all new line from tank to lift pump?
Is 3/8" supply factory or a little bigger?
Diesel
Postby diesel freak01 » Fri Sep 27, 2013 9:51 am
Factory is 5/16 the 3/8 is a bit of an upgrade. Just installed 3/8 on my pile.
1993 d350 ctd drw 2wd auto
diesel freak01
Postby Diesel » Fri Sep 27, 2013 9:32 pm
diesel freak01 wrote:Factory is 5/16 the 3/8 is a bit of an upgrade. Just installed 3/8 on my pile.
Cool. So you ran all rubber line and have no plastic line now? How many feet of the hose will I need for each size?
Diesel
Postby Diesel » Sun Sep 29, 2013 9:00 pm
Just off the cuff estimating 6 feet of each hose should be plenty right?
Diesel
Postby dazedandconfused » Mon Sep 30, 2013 12:20 pm
Make sure you buy diesel rated hose.
Postby Diesel » Tue Oct 01, 2013 8:57 pm
dazedandconfused wrote:Make sure you buy diesel rated hose.
Definitely. Just hoping someone knows how much I need so I can order soon.
Diesel
Postby Remps » Tue Oct 01, 2013 10:03 pm
Regular cab or extended cab?
Postby Diesel » Wed Oct 02, 2013 5:48 am
I have a regular cab.
Diesel
Postby Remps » Wed Oct 02, 2013 9:42 am
Well i am nowhere near my 1st gens to take a measurement, but if you measure from the gas cap to the front of the truck it should be more than enough line. Or crawl underneath and run a string from the top of the tank up to the lp or ip if you want a more accurate measurement.
Postby Remps » Wed Oct 02, 2013 9:49 am
I just noticed you are dropping the tank, if it were mine I would get an aftermarket drawstraw as well. Or at least pull the factory one and inspect and clean it. Isnt there a screen on the factory one that can get dirty?
Postby RCCUMMINS89 » Wed Oct 02, 2013 10:22 am
Yes there is a screen and anything thicker than diesel can clog it.
IMO the best mod is to do what BC847 did............pull the factory sending unit and replace the factory draw straw with a larger hose.
Postby Diesel » Wed Oct 02, 2013 9:05 pm
I like the idea of upgrading all the way up. I'll see if I can find the bc847 mod.
Diesel
Postby DodgeFreak » Thu Oct 03, 2013 5:10 am
I used 3\8 hyd. line and I cut off 20' and it was more than enough almost double if I remember right. when I redo it I'll be going 1\2 supply and 3\8 return I think.
