Rubber Fuel Line Replacement
Re: Rubber Fuel Line Replacement
Postby JimmieD » Thu Oct 03, 2013 10:20 pm
Just a side comment but on my truck I installed a piece of clear plastic tubing for the last foot or so of fuel line before the fuel filter. That way I can tell at a glance if the fuel is getting to filter, or if there's air or water. I just used some ordinary 'Clear vinyl tubing' from the hardware store, with a little piece of steel tubing to patch it in with clamps. It has worked fine for the last 5-6 years so far.
1967 Dodge D-100 Town Wagon - CPL 858 4BT, HTT Stage II/H1C 16cm/56cm turbo, '93 CTD I/C, 32K spring, minor fuel tweaks, milled head, NV4500, 1 ton springs, '72 D-200 Frt. axle w/ Air Lift bags, 4.10 Dana 60HD, F/R swaybars, Tom Woods shaft.
'90 W-350 gasser...
JimmieD
Postby Diesel » Fri Oct 04, 2013 7:32 am
JimmieD wrote:Just a side comment but on my truck I installed a piece of clear plastic tubing for the last foot or so of fuel line before the fuel filter. That way I can tell at a glance if the fuel is getting to filter, or if there's air or water. I just used some ordinary 'Clear vinyl tubing' from the hardware store, with a little piece of steel tubing to patch it in with clamps. It has worked fine for the last 5-6 years so far.
I had a little Lombardini diesel engine that didn't have a tank. Well I put a little tank on it and didn't have fuel line. Used some vinyl tubing on it and that lasted for years. Actually when I got rid of the engine it still had that line and it was as soft as when it was new. I couldn't believe it would work that long!
1991.5 D250 Intercooled A518
Diesel
Postby Alec » Fri Oct 04, 2013 10:34 am
Just for the record -- I'm pretty sure that plastic lines didn't start until '92. My 91.5 trucks have the newer style tank, sending unit/pickup, etc., but the same metal lines in the frame as the non-IC trucks. My experience is that the metal goes long before the rubber.
'91 W250: Getrag; 3.54's
Alec
Postby Diesel » Fri Oct 04, 2013 12:58 pm
Once I get under there I'll report back whats going on.
Diesel
Postby Tacoclaw » Fri Oct 04, 2013 1:16 pm
Alec wrote:Just for the record -- I'm pretty sure that plastic lines didn't start until '92. My 91.5 trucks have the newer style tank, sending unit/pickup, etc., but the same metal lines in the frame as the non-IC trucks. My experience is that the metal goes long before the rubber.
That's my experience as well, my frame, and everything in it, was much more rusty than another part of it in behind the fuel tank. The rubber lines, though crappy looking, we're intact and it was actually the steel bends that had rusted and had the leak.
Is your truck starting hard or anything?
Postby Diesel » Sun Oct 06, 2013 5:35 am
No hard starting just a little scent of diesel from the truck that wasn't there before.
Diesel
Postby rb70383 » Mon Oct 21, 2013 2:16 am
So replacing the lines, what would be a good upgrade? Just 3/8" when does the 3/8 become a restriction?
Also the 93 Frame I have has the hard plastic lines in it as well.
rb70383
