timing= what degree ?
Postby directinjktn1stgen » Wed Oct 23, 2013 5:55 pm
Wondering what is considered what degree of timing when advancing the pump? I was observing under my hood and happened to look at my timing marks. I have the pump gear advanced 1 tooth and my factory marks lined up. So curious as to how much degrees per tooth and roughly and 1/8"!
1992 w250 4x4 4" custom turbo back exhaust 5x.012 HVLP lift pump 3200 181/210 M3 fuel pin, gated hx35 auto important meters
Jeffery
http://i1259.photobucket.com/albums/ii5 ... af0c34.jpg
directinjktn1stgen
Re: timing= what degree ?
Postby AHineman » Wed Oct 23, 2013 6:10 pm
viewtopic.php?f=4&t=13695
Some good info.
Postby directinjktn1stgen » Wed Oct 23, 2013 6:40 pm
Thanks alot for that ! Very good info i have got to be way to adv for mostly stock :lol: I'll play with it tomorrow and see what i find.
Jeffery
directinjktn1stgen
Postby Sutter1stgen » Wed Oct 23, 2013 8:00 pm
Timing light or indicator tool are really the only sure fire ways of know where your really at.
But as BC847 and some others have pointed out dyno time is a good way to fine tune which timing works best for you.
What may feel good seat of the pants, may look terrible on a dyno print out. I should know I've ether been under, or over timed. Lol.
Eric
Sutter1stgen
Postby RCCUMMINS89 » Wed Oct 23, 2013 8:09 pm
It seems to be about 1/8" equals about 3 degrees worth of sweep. 1 tooth equals 10.
On MOST trucks a tooth skipped and retarded an 1/8 equals stock marks and to the head.
From personal experience it seems that every 15 bar worth of pop pressure equals about 3 degrees. 15 bar is the difference between ve pump and p pump pop pressure (245 vs 260)
Users browsing this forum: No registered users and 92 guests
